Re: Modded Honda Hobbit Overheating Solutions
Graham Motzing /
the cheapest thing you can do is try narrowing the point gap a little bit. i think stock is .016 if i recall, try .014.
the next most expensive thing is going to a bigger jet, the last time i tuned one of these I ended up with a 92 jet. if you have pulled the snorkel thing out, you might want to put that back in, the stock carb seems to prefer it.
tuning your variator also may help, you might be turning goofy high rpm's, in which case you are more likely to overheat. If you dont know what you are doing, you might be better off with a stock or notched variator to take one variable out of the equation.
tuning isn't a 'buy things and throw them at your bike till it works' proposition... its something with a methodology that you go through step by step. if you dont know what you're doing its best to eliminate as many variables as you can and work through things that could be causing the problem 1 by 1. More likely than not, your shaft seals are fine, you probably have an intake air leak, exhaust air leak, wrong timing, wrong jet, or something else free and simple.
  Modded Honda Hobbit Overheating SolutionsTopic by: Jason Angerer Jason Angerer 06/18/12 07:14PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Jason Angerer Jason Angerer 06/18/12 07:27PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Totally normal JBOT Totally normal JBOT 06/18/12 08:02PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Jason Angerer Jason Angerer 06/18/12 08:20PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Totally normal JBOT Totally normal JBOT 06/18/12 08:34PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Totally normal JBOT Totally normal JBOT 06/18/12 08:50PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Jason Angerer Jason Angerer 06/18/12 09:14PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Totally normal JBOT Totally normal JBOT 06/18/12 09:28PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Jason Angerer Jason Angerer 06/18/12 09:53PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Beard Road Bruiser (SoB) Beard Road Bruiser (SoB) 06/18/12 10:39PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Jason Angerer Jason Angerer 06/19/12 12:03AM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Chris HnRz Chris HnRz 06/19/12 12:29AM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Graham Motzing Graham Motzing 06/19/12 11:33AM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Mike Lyions Mike Lyions 06/19/12 04:00AM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Ryan N. Ryan N. 06/19/12 09:08AM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Mike Lyions Mike Lyions 06/19/12 05:41PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: †▲m †▲m †▲m †▲m 06/19/12 10:17PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: †▲m †▲m †▲m †▲m 06/19/12 10:25PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Ryan N. Ryan N. 06/19/12 10:20PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Mike Lyions Mike Lyions 06/19/12 10:37PM
