Re: Modded Honda Hobbit Overheating Solutions
Mike Lyions /
What plug are you running? I dropped about 75 degrees switching from my winter plug to my summer plug. The bigger the electrode the more heat in the cylinder. An 88 jet is too small, I ran an 88 in my stocko shocko kit. You should be in the 90's with 70cc. An 88 jet with leaky crank seals will make you run hot. Replace the crank seals for sure. They can be done without splitting the case. Go to menards and get one of those laser temp gauges for about $40. As far as a bigger Carb, just bore out your stock Carb. I went up to 14mm on mine and it runs fine. (Just be careful if you go that big not to break out the sides) maybe start with a 1/2" drill first which is just under 13mm.
  Modded Honda Hobbit Overheating SolutionsTopic by: Jason Angerer Jason Angerer 06/18/12 07:14PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Jason Angerer Jason Angerer 06/18/12 07:27PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Totally normal JBOT Totally normal JBOT 06/18/12 08:02PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Jason Angerer Jason Angerer 06/18/12 08:20PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Totally normal JBOT Totally normal JBOT 06/18/12 08:34PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Totally normal JBOT Totally normal JBOT 06/18/12 08:50PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Jason Angerer Jason Angerer 06/18/12 09:14PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Totally normal JBOT Totally normal JBOT 06/18/12 09:28PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Jason Angerer Jason Angerer 06/18/12 09:53PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Beard Road Bruiser (SoB) Beard Road Bruiser (SoB) 06/18/12 10:39PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Jason Angerer Jason Angerer 06/19/12 12:03AM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Chris HnRz Chris HnRz 06/19/12 12:29AM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Graham Motzing Graham Motzing 06/19/12 11:33AM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Mike Lyions Mike Lyions 06/19/12 04:00AM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Ryan N. Ryan N. 06/19/12 09:08AM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Mike Lyions Mike Lyions 06/19/12 05:41PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: †▲m †▲m †▲m †▲m 06/19/12 10:17PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: †▲m †▲m †▲m †▲m 06/19/12 10:25PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Ryan N. Ryan N. 06/19/12 10:20PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Mike Lyions Mike Lyions 06/19/12 10:37PM
