Re: Modded Honda Hobbit Overheating Solutions
Jason Angerer /
Lol alright. Well I already have a clutch puller. I guess I need a second jaw puller as well? And i guess while I'm at it should I change any other seals? Or even replace the crank as well? I have read that an 88 jet with the same mods on other hobbits is about right possibly even slightly rich. I havnt done a plug chop but just by looking at the plug it looks almost black not grey which would indicate its running lean. I get the whole running lean at high rpm aspect of the seals tho.
How much is the jaw puller and seals?
Also I know if I'm going to take everything apart to get to the seals I might as well replace the cdi unit as well... And others say after you install the new cdi you often have to down jet.
What size jet do you ru in your setup?
Seals are cheap and easy to install but I'm doughting just seals will fix the whole problem.
Hobbits are natorious for running hot even with good seals.
I'm assuming you installed a cdi? Did it make a big difference?
I don't have tons of money to drop either. So after I replace the $5 seals what's next becase I know that won't be enough to drastcaly drop the temp for prolonged riding.
  Modded Honda Hobbit Overheating SolutionsTopic by: Jason Angerer Jason Angerer 06/18/12 07:14PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Jason Angerer Jason Angerer 06/18/12 07:27PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Totally normal JBOT Totally normal JBOT 06/18/12 08:02PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Jason Angerer Jason Angerer 06/18/12 08:20PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Totally normal JBOT Totally normal JBOT 06/18/12 08:34PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Totally normal JBOT Totally normal JBOT 06/18/12 08:50PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Jason Angerer Jason Angerer 06/18/12 09:14PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Totally normal JBOT Totally normal JBOT 06/18/12 09:28PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Jason Angerer Jason Angerer 06/18/12 09:53PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Beard Road Bruiser (SoB) Beard Road Bruiser (SoB) 06/18/12 10:39PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Jason Angerer Jason Angerer 06/19/12 12:03AM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Chris HnRz Chris HnRz 06/19/12 12:29AM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Graham Motzing Graham Motzing 06/19/12 11:33AM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Mike Lyions Mike Lyions 06/19/12 04:00AM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Ryan N. Ryan N. 06/19/12 09:08AM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Mike Lyions Mike Lyions 06/19/12 05:41PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: †▲m †▲m †▲m †▲m 06/19/12 10:17PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: †▲m †▲m †▲m †▲m 06/19/12 10:25PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Ryan N. Ryan N. 06/19/12 10:20PM
  Re: Modded Honda Hobbit Overheating SolutionsRe: Mike Lyions Mike Lyions 06/19/12 10:37PM
