I've got 2 projects I wanted to do that involves chopping up this junked Zuma motor I have here, and making it the powerplant for a moped, but I'm really torn on which would be more fun to build and ride....
Project 1: "Zerbi"
Chop the Zuma tranny up to shorten it a bunch, then mount it derbi style with a sprocket running off the rear axle shaft to a sprocket on the rear wheel. Probably use a hobbit frame which I'd add a swingarm with pedals, and use these weird 16in gizmo mags. Advantage in doing this is that I can adjust gearing easily with sprockets. Can't do this as easily with project 2 (see below)
Project 2: no name yet...
Hobbit frame with Aprilia Scarabeo rims and motor, but lengthen the rear scarabeo trans swingarm and add a pedal shaft in the swingarm hobbit style.
I'd have to add a second swingarm and shock on the right side for added support, which would just help keep it all solid.
They are both stupid and fun, and id like to do both..but only have one motor to chop up and one extra hobbit frame....
Vat to dooooooooo? (edited)
