Bingzilla 18mm Bing Carburetor? 77mopeds
Does anyone have or has seen this carb?
I need to know about quality? square jets or reg jets? anything different then the smaller bings?
I would like to use my 12mm bing for parts on this bigger carb.
Re: Bingzilla 18mm Bing Carburetor? 77mopeds
I believe those bigger bings are multi jet but I'm not sure. It looks to be. Just get a phbg or scour for a 17 Bing as they are single jet. Also I don't have a clue what intake you'd run with that 18 I feel its harder to make a clamp style intake not have air leaks unless its done well.
pretty sure parts are only interchangeable on 12 through 15
Probably Fred /
Some 12-15mm parts fit on the 17mm like the bowl, needle, clip, top clip, screws, bendy thing, choke lever and primer
Atomizer and jets too. Oh and the 17 Bing has a longer needle not that a 12-15 wouldn't fit you'd just be crazy rich early.
Probably Fred /
I didn't say atomizer because you need a#215 atomizer and ya the needle is longer but I used a short one before
Hey you don't happen to have one of these 215 atomizers do ya ken? A 217 doesn't run that great in these.
