Re: Noobie question. Do I need to change my timing?
Graham Motzing /
you can probably just turn the stator plate a little bit retarded and 'feel' for where the timing is the best. the bike will probably want it to be a few degrees retarded of stock, so just try turning the stator a little at a time and feel for where it runs the best.
but yeah, check to make sure your stock timing is good, good points, etc.
