Am I using a jet that's too high? puch maxi luxe
I have a stock 78 Maxi Luxe 1.5hp w/ stock pipes and 12mm bing(1/12/310). The stock jet is a #48. I just ordered a "puch bing metal hi flow filter", "puch tecno circuit performance exhaust pipe" and a set of all 70s jets from Treatland. The question is, do you thing a jump from a 48 stock jet to a 70s jet is to much? Even with the upgrades.
I know its hard for someone to tell me what jet to use but I just need to know if it is probably a 50s or 60s jet.
P.S. what happens if i use a jet that's too high?
Re: Am I using a jet that's too high? puch maxi luxe
Probably Fred /
About a # 62 jet with #222 atomizer. If you got a goofy 212A atomizer in your carb maybe mid 50s jet who knows.
You got to get rid of your stock restrictive non expandsion exhaust. Puch maxi stock exhaust is horrible it's only there to make you go slow to meet certain regulations. Get a performance pipe even a cheap one like jammy will be better then stock junk
yep, 70's will be too big
