Kstar to Spigot Mount PHGB Intake options
Luke “Funkenet” Hosfield /
There aren't very many options that are available to buy so I ended up making my own out of a puch pipe header.
I don't like it very much. Its not perfectly round so its difficult to get the spigot to seal around it. Besides I don't like having my carb facing forward.
So what are my options? Any ideas?
19mm carb btw.
Re: Kstar to Spigot Mount PHGB Intake options
If you get too close to the bend it isn't round. If you have the clamp on carb 3/4 copper plumbing pipe can go into it and then hose join the copper pipe stub to the header now intake
Huh?
I have the spigot mount carb
rad hose and clamps is the way IMO.
Yeah I know that much, I want something I can mount the carb facing the rear wheel. Or just not facing forward. I am thinking if I can find a right mounting pipe that is the right size I could get something working.
NoISy BOyS KEV /
I made my first intake out of an old toddler bike handlebar set... 19mm I.D.
get a small piece of flat steel, cut the flange, bore the hole, drill mount holes, weld your 90 on in any desired direction and blast.
If you dont want to make a flange you could just cut the one off your current intake. I'm always looking for new ways to build intakes... Here's my latest, It's part of a walker. 21mm I.D. $0.00 invested :)
whAT'S WITH THESPRING?
A Boy Named Britchez ... /
^Spring is, of course, a marvelous thing.
My favorite option is using a solo odyssey header as an intake. Lets the carb sit above the flywheel cover, and it's 19mm i.d. Bolts right on to puch intake stud spacing too.
Ohh I like the solo odyssey header idea. Any pics of it?
what is up with the spring?
My guess is the spring is for extra heat displacement?
