Re: Wizard Powers Revisited (NU50M)
Noped Steve /
Hey Chris, Gruff thanks for the props. As for your questions Chris, the race gears were a couple thousands of an inch too large of an I.D. to fit directly on my NU50 shaft. I don't know for sure, maybe mine were made for Dio or another Honda model still more obscure. I got them from Shannon Hall, and just thought they were the same "race gears" everybody else has been trying on their Urbans, so don't quote me on the name. Differences between them include 14t final drive (vs. 17t stock) and a straight cut gear bevel vs. the angled ones that came stock. Naz ended up welding the gears to a spare rear shaft I had that I had bought off fleabay for that purpose. If for any reason the modded gears blow up or separate from the stock NU shaft, I have a complete set of stocker gears to put back in. That said, everything feels solid and we anticipate no problems with them long term. To check for deterioration of the mating, I will change the final drive gear oil out a couple times here over the next couple hundred miles and look for shavings in the juice. I'll let you guys know if there are any issues but things seem fine for now.
As for the TJT plate- I'm trippin'- pretty sure it was made for Caminos, sorry for the confusion. In order to get that to work, we had to weld in a small washer into the hole in the center of the plate, as the inner hole was a bit large for the NU variator shaft. Naz machined out a hole the correct size for the shaft and, all is working very well now with minimal hang up top when decelerating, which was a huge issue with the notched variator.
  Wizard Powers Revisited (NU50M)Topic by: Noped Steve Noped Steve 06/14/12 02:18PM
  Re: Wizard Powers Revisited (NU50M)Re: Flagrant - Flagrant - 06/14/12 02:23PM
  Re: Wizard Powers Revisited (NU50M)Re: Kevin M Kevin M 06/14/12 02:29PM
  Re: Wizard Powers Revisited (NU50M)Re: Jesse Stephenson Jesse Stephenson 06/14/12 02:44PM
  Re: Wizard Powers Revisited (NU50M)Re: Born to be WillD Born to be WillD 06/14/12 03:45PM
  Re: Wizard Powers Revisited (NU50M)Re: Flagrant - Flagrant - 06/14/12 03:54PM
  Re: Wizard Powers Revisited (NU50M)Re: Kevin M Kevin M 06/14/12 04:11PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 06/14/12 07:31PM
  Re: Wizard Powers Revisited (NU50M)Re: Chris . Chris . 06/14/12 10:25PM
  Re: Wizard Powers Revisited (NU50M)Re: Gruff "(OFMC)" - Gruff "(OFMC)" - 06/14/12 10:28PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 06/14/12 10:51PM
  Re: Wizard Powers Revisited (NU50M)Re: Rick Ems Rick Ems 06/14/12 11:54PM
  Re: Wizard Powers Revisited (NU50M)Re: Michael Mike Naz Michael Mike Naz 06/15/12 03:35AM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 06/15/12 09:22AM
  Re: Wizard Powers Revisited (NU50M)Re: Matthew Chedda Matthew Chedda 06/15/12 06:29PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 06/16/12 01:58PM
  Re: Wizard Powers Revisited (NU50M)Re: Kevin M Kevin M 06/18/12 12:15PM
  Re: Wizard Powers Revisited (NU50M)Re: *.* HONDA *.* HONDA 06/19/12 12:34AM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 06/21/12 10:51AM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 06/21/12 11:07AM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 06/21/12 11:14AM
  Re: Wizard Powers Revisited (NU50M)Re: Ryan Perkins Ryan Perkins 06/21/12 12:52PM
  Re: Wizard Powers Revisited (NU50M)Re: Emil Kniemel Emil Kniemel 07/09/12 02:45PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 07/09/12 02:58PM
  Re: Wizard Powers Revisited (NU50M)Re: Rick Ems Rick Ems 07/10/12 12:35AM
  Re: Wizard Powers Revisited (NU50M)Re: Charles Cole (OFMC) Charles Cole (OFMC) 07/10/12 01:09AM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 07/10/12 12:48PM
  Re: Wizard Powers Revisited (NU50M)Re: Michael Mike Naz Michael Mike Naz 07/10/12 02:12AM
  Re: Wizard Powers Revisited (NU50M)Re: Rick Ems Rick Ems 07/10/12 05:56AM
  Re: Wizard Powers Revisited (NU50M)Re: Born to be WillD Born to be WillD 07/10/12 01:44PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 12/04/12 02:54PM
  Re: Wizard Powers Revisited (NU50M)Re: ! West Seattle ! ! West Seattle ! 12/04/12 02:58PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 12/04/12 03:03PM
  Re: Wizard Powers Revisited (NU50M)Re: Jake P Jake P 12/04/12 03:50PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 12/04/12 04:02PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 01/29/13 01:22PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 01/29/13 01:33PM
