Wizard Powers Revisited (NU50M)
Noped Steve /
The Wizard of Naz has granted me new powers in the form of the re-engineered Runaway Rally Ped. What do you think?
Current Setup highlights:
1984 Honda Runaway aka NU50M
Stock Case and Crank
Treats Wizard Cylinder kit w Wiseco Piston
Puch 50cc Cylinder head with custom squish band
Custom base spacer for cylinder to fit NU50
Gates BX33 Belt
27g weights in a "stock" 6 roller variator
TJT Honda Dio ramp plate customized to fit NU50
107mm Scooter Clutch
1500 rpm (red) tension spring for clutch
Honda Dio 4 Petal reed block
Trick Metric Dio intake adapter
Mikuni TM24 Flatslide carb, 210 main
Honda oil injection system
Proma Circuit exhaust (custom mounts to fit NU50)
2002 Marzocchi Monster fork (40mm stanchions, 175mm travel, 20mm thru axle, externally adjustable Compression, Preload, and Rebound, internal low speed compression adjust)
Custom 1" steerer tube for fork installed on a hybrid sealed bearing MTB headset with roller bearings in lower cup, full custom setup
Aftermarket Honda CRF50 Rear Shock, (11" length, nitrogen charged piggyback with adjustable rebound, preload)
Custom front wheel (20mm axle MTB hub with 48 spokes laced three cross on an Odyssey triple wall 20" 48 spoke BMX hoop)
Pit Bike front disc caliper and M/C mounted to fork with custom caliper adapter and mini disc rotor
Malossi PX50 Speed gears specially adapted to fit NU50 rear hub
31.8 clamp diameter DH MTB Handlebars, Snafu stem
Stock Honda controls (turn signals, horn, electric starter intact)
Shinko giant knobby tires (17x3.0 front 14x2.75 rear)
BMX Beartrap pedals mounted on a custom threaded shaft for easy pedal swaps in future.
Stock headlight on custom Stainless Steel mount
Custom Stainless Steel Battery Box bracket with latch
CRF50 Front and rear fenders
We are working out some little details like what air filter I want to run, but the bike starts and idles beautifully, and pulls like a truck up to what feels like a solid 50mph- I will provide some GPS data on that as soon as we are through tuning. The old setup ( https://www.mopedarmy.com/forums/read.php?7,2111611,2925053#msg-2925053 ) achieved over 50 mph numerous times in my quest to blow it up, so I expect this build to equal or better that without most of the issues I encountered with either the shady Wizard Kit piston, tiny stock carb, or iffy performing notched variator used to get there before.
This has been a really fun project and was only possible at all with some serious engineering on the part of Naz.
http://www.xtranormal.com/watch/7268501/i-like-mopeds
  Wizard Powers Revisited (NU50M)Topic by: Noped Steve Noped Steve 06/14/12 02:18PM
  Re: Wizard Powers Revisited (NU50M)Re: Flagrant - Flagrant - 06/14/12 02:23PM
  Re: Wizard Powers Revisited (NU50M)Re: Kevin M Kevin M 06/14/12 02:29PM
  Re: Wizard Powers Revisited (NU50M)Re: Jesse Stephenson Jesse Stephenson 06/14/12 02:44PM
  Re: Wizard Powers Revisited (NU50M)Re: Born to be WillD Born to be WillD 06/14/12 03:45PM
  Re: Wizard Powers Revisited (NU50M)Re: Flagrant - Flagrant - 06/14/12 03:54PM
  Re: Wizard Powers Revisited (NU50M)Re: Kevin M Kevin M 06/14/12 04:11PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 06/14/12 07:31PM
  Re: Wizard Powers Revisited (NU50M)Re: Chris . Chris . 06/14/12 10:25PM
  Re: Wizard Powers Revisited (NU50M)Re: Gruff "(OFMC)" - Gruff "(OFMC)" - 06/14/12 10:28PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 06/14/12 10:51PM
  Re: Wizard Powers Revisited (NU50M)Re: Rick Ems Rick Ems 06/14/12 11:54PM
  Re: Wizard Powers Revisited (NU50M)Re: Michael Mike Naz Michael Mike Naz 06/15/12 03:35AM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 06/15/12 09:22AM
  Re: Wizard Powers Revisited (NU50M)Re: Matthew Chedda Matthew Chedda 06/15/12 06:29PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 06/16/12 01:58PM
  Re: Wizard Powers Revisited (NU50M)Re: Kevin M Kevin M 06/18/12 12:15PM
  Re: Wizard Powers Revisited (NU50M)Re: *.* HONDA *.* HONDA 06/19/12 12:34AM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 06/21/12 10:51AM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 06/21/12 11:07AM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 06/21/12 11:14AM
  Re: Wizard Powers Revisited (NU50M)Re: Ryan Perkins Ryan Perkins 06/21/12 12:52PM
  Re: Wizard Powers Revisited (NU50M)Re: Emil Kniemel Emil Kniemel 07/09/12 02:45PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 07/09/12 02:58PM
  Re: Wizard Powers Revisited (NU50M)Re: Rick Ems Rick Ems 07/10/12 12:35AM
  Re: Wizard Powers Revisited (NU50M)Re: Charles Cole (OFMC) Charles Cole (OFMC) 07/10/12 01:09AM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 07/10/12 12:48PM
  Re: Wizard Powers Revisited (NU50M)Re: Michael Mike Naz Michael Mike Naz 07/10/12 02:12AM
  Re: Wizard Powers Revisited (NU50M)Re: Rick Ems Rick Ems 07/10/12 05:56AM
  Re: Wizard Powers Revisited (NU50M)Re: Born to be WillD Born to be WillD 07/10/12 01:44PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 12/04/12 02:54PM
  Re: Wizard Powers Revisited (NU50M)Re: ! West Seattle ! ! West Seattle ! 12/04/12 02:58PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 12/04/12 03:03PM
  Re: Wizard Powers Revisited (NU50M)Re: Jake P Jake P 12/04/12 03:50PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 12/04/12 04:02PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 01/29/13 01:22PM
  Re: Wizard Powers Revisited (NU50M)Re: Noped Steve Noped Steve 01/29/13 01:33PM
