Best choice in carb and jetting?
https://www.treatland.tv/ProductDetails.asp?ProductCode=sachs-giannelli-pipe&CartID=1
And I'm changing my front sprocket to 12t for my Westlake with a 508 or 504c.
What size carb intake do these even use? I'm totally clueless when it comes to carbs and what makes a carb good and could use some help.
Re: Best choice in carb and jetting?
Probably Fred /
If you clueless in carbs you may be clueless in cutting cylinder fins and grinding to fit this pipe. Mounting will need bracket fabration/welding. And then you got to jet/tune the carb. A D engine works best with this pipe
