Re: Setting Points on Peugeot
SABAT! andDestroy /
clutch side marks is a good idea.
i use a suzuki ignition timing tool, dail in Tdc, roll back 2mm the forward .2
then do trial and error getting on the flywheel a bunch of times till im spot on.
so im 1.8 exact right now, where should i put marks on the clutch side?
i've got 1.8 and TDC marked on the mag side already.
