Re: Stock Peugeot 103 Tuning!!
Charlie BUZZARD /
Yup, glad you asked...
Get this guy... It's a micrometer. You will be using the probe end of it to measure mm's before top dead center, or TDC. (Some people refer to this as BTDC)
Okay, pull your flywheel, and your spark plug. Insert the probe the little measuring stick coming out the end of it, lol) of the Micrometer (or Mike for short) into the sparkplug hole. Be sure that the butt end of the Mike is resting evenly across the sparkplug hole. I rest the top of the Mike against my fender to insure that the angle that I'm holding it at doesn't vary. Hold the Mike firmly against the cylinder hear, as to where the only part that moves will be the probe. The idea here is to accurately measure the lateral movement of the piston within the cylinder. Okay so now turn the clutch side of the crank to move the piston, since you have pulled your fly wheel, and try to find TDC. Put pressure on the bottom jaw of the Mike so when the piston reaches its apex you will know. While turning the clutch side you will notice the numbers on the Mike going up and then start to drop. Find the exact point where the numbers on the Mike are at their highest. That's your TDC! Hold your clutch side right there, DO NOT LET IT MOVE. If it moves again, you'll be finding TDC again.
Now assuming that you have found TDC and haven't let the clutch side move at all, let's move forward. Okay so, leaving the Mike just as you had it, you have your measurement of where TDC is. You want to find your desired measurement of BTDC now (before top dead center). I set mine at 1.8 BTDC for stock. I have wanted to play with the settings but I stripped my crank nut... so fuck it. It works fine for me at 1.8 BTDC. The pug motors rotate forward, or clockwise if you are sitting on the flywheel side of the bike. With that being said, in order to find BTDC you will want to rotate the crank backward to find this. Now, if you have the option to "zero" your Mike do that now. If not then just subtract 1.8mm or whatever your desired setting is. Now that you have found 1.8 BTDC, hold that clutch side still, or risk doing this all over agian.
Assuming that you have found your desired measurement BTDC, let's move forward. Now you are going to want to find the exact point where the points open. You will want to set your flywheel exactly at the point that the lobe, or cam, on the inside of the fly wheel begins to open the points on the stator plate. Do this by sliding the fly wheel on the crank and rotating it forward, while looking at the points through the windows on the fly wheel. You will need a super well lit room, or a flash light, or both, lol. Some put the cellophane wrapper from a cigarette package between the points and when the points loosen their grip on the cellophane, it signifies exactly when they begin to open. I just eye it. All the while you should be holding the clutch side (or having a trust worthy friend hold it, lol) in the exact possition of your desired BTDC.
Assuming that the piston is at X.Xmm BTDC, and the the flywheel is at exact position where the points begin open, now you are going to want to set the flywheel on the crank in its exact position. Again, if you have let anything move, you are going to want to start all over. Now with at rubber mallet, smack the fly wheel on the the crank. This will set the flywheel on the taper of the crank, allowing you to let go and tighten the flywheel nut. Give it a few good smacks before you let anything move to insure that the flywheel is good and stuck on the taper of the crank. Be careful to hit the fly wheel dead center, and not of to one side. This will insure a good fitment onto the taper and it will protect against the off chance that you may knock the flywheel off balance.
Now that the Flywheel is set firmly in place, All is left to do is tighten the flywheel nut and put your spark plug back in. I use a impact wrench to take this nut on and off, but if you don't have one of these, you can just use a spanner, or a piston stop, or even the rope trick. It's up to you. If you have done everything correctly (assuming you chose a suitable X.Xmm's BTDC) , then your ped should be timed perfectly.
Now go ride it with a smile on your face, knowing you have mastered your shitty pug ignition.
  Stock Peugeot 103 Tuning!!Topic by: Charlie BUZZARD Charlie BUZZARD 06/12/12 11:03AM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 06/12/12 11:12AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 06/12/12 11:19AM
  Re: Stock Peugeot 103 Tuning!!Re: Marvin Chan Marvin Chan 06/12/12 12:24PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 06/19/12 09:45PM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 06/20/12 10:18AM
  Re: Stock Peugeot 103 Tuning!!Re: Rebel Moby Rebel Moby 06/20/12 11:46AM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 06/20/12 12:36PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 06/20/12 12:42PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 06/20/12 02:05PM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 06/20/12 06:02PM
  Re: Stock Peugeot 103 Tuning!!Re: Mel Dyer Mel Dyer 06/20/12 06:24PM
  Re: Stock Peugeot 103 Tuning!!Re: Rachel LGN Rachel LGN 07/16/12 01:47PM
  Re: Stock Peugeot 103 Tuning!!Re: kyle uhl kyle uhl 01/18/13 02:38PM
  Re: Stock Peugeot 103 Tuning!!Re: Steven Dewaele Steven Dewaele 11/10/13 08:31AM
  Re: Stock Peugeot 103 Tuning!!Re: Dirty30 Dillon Dirty30 Dillon 11/10/13 09:10AM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 11/10/13 09:39AM
  Re: Stock Peugeot 103 Tuning!!Re: Brandon Compton Brandon Compton 06/20/12 06:42PM
  Re: Stock Peugeot 103 Tuning!!Re: jumpsuit steve jumpsuit steve 07/07/12 05:40PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/16/12 03:56PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/16/12 11:54PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 07/17/12 09:58AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/17/12 11:29AM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 07/17/12 11:39AM
  Re: Stock Peugeot 103 Tuning!!Re: [\/] |=| [\/] |=| 07/23/14 02:44AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/17/12 11:31AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/17/12 05:00PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/18/12 06:59PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/18/12 11:49PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/19/12 10:23AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/19/12 12:53PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/19/12 12:59PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/19/12 04:09PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/21/12 02:05PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/22/12 12:40AM
  Re: Stock Peugeot 103 Tuning!!Re: CtpEDsHED . CtpEDsHED . 07/22/12 09:46AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/22/12 03:57PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/23/12 11:39AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/24/12 11:45AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/24/12 03:01PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 07/24/12 03:36PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/24/12 03:47PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 07/24/12 03:59PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/26/12 12:33AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/26/12 09:51AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/26/12 10:55AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/26/12 10:56AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/26/12 01:09PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/26/12 02:08PM
  Re: Stock Peugeot 103 Tuning!!Re: Aeron Jackson Aeron Jackson 08/03/12 01:11PM
  Re: Stock Peugeot 103 Tuning!!Re: mit mortso mit mortso 08/03/12 02:35PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 08/03/12 03:36PM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 08/04/12 12:30AM
  Re: Stock Peugeot 103 Tuning!!Re: Rachel LGN Rachel LGN 08/09/12 02:47AM
  Re: Stock Peugeot 103 Tuning!!Re: Kevin Hurt Kevin Hurt 01/16/13 09:12PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 01/16/13 10:31PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 01/16/13 11:07PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 01/16/13 11:20PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 01/16/13 11:38PM
  Re: Stock Peugeot 103 Tuning!!Re: Kevin Hurt Kevin Hurt 01/16/13 11:40PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 01/16/13 11:46PM
  Re: Stock Peugeot 103 Tuning!!Re: cheetahchrome . cheetahchrome . 01/17/13 12:12AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 01/18/13 04:13PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 01/18/13 04:27PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 01/18/13 04:28PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 01/18/13 05:36PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 01/18/13 08:08PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/06/13 02:05AM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 08/06/13 08:26AM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/06/13 02:32PM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 08/06/13 03:27PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 08/06/13 08:37PM
  Re: Stock Peugeot 103 Tuning!!Re: cj cj cj cj 08/12/13 01:55PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/06/13 04:57PM
  Re: Stock Peugeot 103 Tuning!!Re: Dirty30 Dillon Dirty30 Dillon 08/06/13 05:21PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/06/13 06:23PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/10/13 03:14AM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 08/11/13 09:00AM
  Re: Stock Peugeot 103 Tuning!!Re: roadent$ craig roadent$ craig 08/11/13 10:14AM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/12/13 10:25AM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 08/12/13 10:37AM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 08/12/13 11:11AM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/12/13 11:28AM
  Re: Stock Peugeot 103 Tuning!!Re: Brad Olivier Brad Olivier 08/12/13 11:39AM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 08/12/13 12:13PM
  Re: Stock Peugeot 103 Tuning!!Re: Nathan Schmidt Nathan Schmidt 08/12/13 05:22PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 08/12/13 05:38PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 08/12/13 06:06PM
  Re: Stock Peugeot 103 Tuning!!Re: Max Allana Max Allana 10/05/15 06:51PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 10/05/15 07:57PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/13/13 10:06AM
  Re: Stock Peugeot 103 Tuning!!Re: david s david s 11/09/13 12:18PM
  Re: Stock Peugeot 103 Tuning!!Re: Nathan Schmidt Nathan Schmidt 12/23/13 06:54PM
  Re: Stock Peugeot 103 Tuning!!Re: Steven Dewaele Steven Dewaele 12/24/13 04:11AM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 12/24/13 08:49AM
  Re: Stock Peugeot 103 Tuning!!Re: Steven Dewaele Steven Dewaele 12/24/13 09:09AM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 12/24/13 10:29AM
  Re: Stock Peugeot 103 Tuning!!Re: Steven Dewaele Steven Dewaele 12/24/13 12:54PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 01/03/14 09:53PM
  Re: Stock Peugeot 103 Tuning!!Re: Nestor Aquino Nestor Aquino 01/02/14 06:27PM
  Re: Stock Peugeot 103 Tuning!!Re: french gimiks french gimiks 01/03/14 09:29PM
  Re: Stock Peugeot 103 Tuning!!Re: Sal RVA mopeds LLC Sal RVA mopeds LLC 03/18/14 01:51AM
  Re: Stock Peugeot 103 Tuning!!Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 03/18/14 05:00AM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 03/18/14 10:04AM
  Re: Stock Peugeot 103 Tuning!!Re: Bobby G Bobby G 03/18/14 05:06PM
  Re: Stock Peugeot 103 Tuning!!Re: Sal RVA mopeds LLC Sal RVA mopeds LLC 08/01/14 02:53PM
  Re: Stock Peugeot 103 Tuning!!Re: The Real Mike D The Real Mike D 08/02/14 11:40AM
  Re: Stock Peugeot 103 Tuning!!Re: Sal RVA mopeds LLC Sal RVA mopeds LLC 08/06/14 01:44AM
  Re: Stock Peugeot 103 Tuning!!Re: Dirty30 Dillon Dirty30 Dillon 08/06/14 09:37AM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 08/06/14 09:40AM
  Re: Stock Peugeot 103 Tuning!!Re: Sal RVA mopeds LLC Sal RVA mopeds LLC 08/07/14 01:17AM
  Re: Stock Peugeot 103 Tuning!!Re: kevin - kevin - 10/20/14 09:49PM
  Re: Stock Peugeot 103 Tuning!!Re: Kevin Hurt Kevin Hurt 10/20/14 11:33PM
  Re: Stock Peugeot 103 Tuning!!Re: Mopedicures Pedals4show Mopedicures Pedals4show 10/16/15 05:28PM
  Re: Stock Peugeot 103 Tuning!!Re: Mopedicures Pedals4show Mopedicures Pedals4show 10/16/15 07:40PM
  Re: Stock Peugeot 103 Tuning!!Re: Narro *UPJET* Narro *UPJET* 06/08/16 05:16AM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 06/08/16 09:07AM
  Re: Stock Peugeot 103 Tuning!!Re: Narro *UPJET* Narro *UPJET* 06/10/16 02:44PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 06/10/16 02:51PM
  Re: Stock Peugeot 103 Tuning!!Re: Narro *UPJET* Narro *UPJET* 06/11/16 03:56PM
  Re: Stock Peugeot 103 Tuning!!Re: Narro *UPJET* Narro *UPJET* 06/08/16 05:37AM
  Re: Stock Peugeot 103 Tuning!!Re: Toledo Riot Toledo Riot 10/03/19 10:46AM
  Re: Stock Peugeot 103 Tuning!!Re: L e e L e e 01/02/22 03:28PM
  Re: Stock Peugeot 103 Tuning!!Re: L e e L e e 01/02/22 03:34PM
  Re: Stock Peugeot 103 Tuning!!Re: L e e L e e 01/02/22 03:38PM
  Re: Stock Peugeot 103 Tuning!!Re: L e e L e e 01/02/22 03:40PM
  Re: Stock Peugeot 103 Tuning!!Re: L e e L e e 01/02/22 03:53PM
  Re: Stock Peugeot 103 Tuning!!Re: Stephen Simmons Stephen Simmons 01/02/22 04:09PM
