Re: Stock Peugeot 103 Tuning!!
Charlie BUZZARD /
Okay guys, sorry it took so long to update this thread. I have some up dates.
@Sabat: You are exactly right. The bike wants to idle lower than the carb will let it. It has the some of the same symptoms as a clutch that wont disengage. I have tried the slotting the slide trick (simular to the bing buddy hole trick) with okay results. I had a 17 bing laying around and decided to toss that bad boy on there seeing it was closer to my 16mm intake. BINGO, pun intended! I think I threw in a 71 jet, it was perrrrrfect idle first try. I haven't touched it since. Well, other than the carb slipping of. BLK BLK Shaun gave me a brass shim at the RVA rally, so I replaced the old carb spray can shim that I made with that one and its been holding steady ever since. But to sum it up, get another carb. Try a 14 bing maybe, or a 15:15 sha. But if you have a 17 Bing, its gold...
Okay, so after the 17 Bing this bike woke the fuck up... I could feel it wanting to go faster. So I decided to nut up and port the cylinder. There is a small lip casted within the window of the exhaust port. File that shit out. I used a dremel, but you do what you feel okay with. This helped me out a good bit on top end.
I still felt like shit could be peppier... I read and read about tuning the stock vario. I hear tell about lightening the weights too much and not getting its full variation. Well I don't want any parts of that. If she is going to be stock, she needs every stitch of top end she can get. Answer... LAUNCH LEVER, lol. the Polini on will bolt right on to the stock cases, just flip the hardware to make room for the nuts. Now you decide we your bike variates! Oh shoot, that guy is blasting you, "wuuuh WAAAAAAAAAAHH!!!!" Damn this hill... "wuuuuh WAAAAAAAAH!!" Granted this isn't for the lazy folks. You can tune the vario weights and do this with comparable results, I just dont care to. It's super fun to hold it in lower gear, and control the variation.
Okay, on to the external condensor. I will take pics of this tomorrow and do a write up on how to for the five coil. I know this will not help the majority of you, but its what I gots. I replaced this and the HT coil as a preemptive measure, as I don't like pedaling my moped. I had a coil left over from an old hpi set up, and I tossed it in there. It sparks awesome. I mounted it in the same place as the original, but moved it to the back side of the mount to clear the side covers. To insure a good ground, I ground off the paint here, and I ran some solid copper grounds to a head stud. Shit gets FAT spark. I have noticed a slight gain in performance from this believe it or not. The bike just seems to run smoother.
Okay, so with all of that shit done, I'm gps'ing my Pug at about 38 sitting up on flats. I can put my feet on the side covers and duck down some and get 40, easy. I took it to the RVA rally and it blasted. I'm so in love with this bike, I can't begin to describe. I have looked around for info on what pipe is best on a stock set up, and I haven't gotten anything solid, so I'm going out on the limb tonight and ordering a small circuit pipe.
Stay tuned for the five coil external condensor and HT coil replacement, the what ever pipe I buy review, and further porting on the cylinder!! I'm aiming at 45 on the stocker. Future plans also include a cast iron polini, and ninja g3 pipe. But that will be another thread.
If you know of a pipe that works well with stock, then please share it! This thread is all about providing concentrated, concise info for those who want the most out of their stock pugs. Why should the puch and tomos guys be the only well versed cats out there?
  Stock Peugeot 103 Tuning!!Topic by: Charlie BUZZARD Charlie BUZZARD 06/12/12 11:03AM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 06/12/12 11:12AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 06/12/12 11:19AM
  Re: Stock Peugeot 103 Tuning!!Re: Marvin Chan Marvin Chan 06/12/12 12:24PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 06/19/12 09:45PM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 06/20/12 10:18AM
  Re: Stock Peugeot 103 Tuning!!Re: Rebel Moby Rebel Moby 06/20/12 11:46AM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 06/20/12 12:36PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 06/20/12 12:42PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 06/20/12 02:05PM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 06/20/12 06:02PM
  Re: Stock Peugeot 103 Tuning!!Re: Mel Dyer Mel Dyer 06/20/12 06:24PM
  Re: Stock Peugeot 103 Tuning!!Re: Rachel LGN Rachel LGN 07/16/12 01:47PM
  Re: Stock Peugeot 103 Tuning!!Re: kyle uhl kyle uhl 01/18/13 02:38PM
  Re: Stock Peugeot 103 Tuning!!Re: Steven Dewaele Steven Dewaele 11/10/13 08:31AM
  Re: Stock Peugeot 103 Tuning!!Re: Dirty30 Dillon Dirty30 Dillon 11/10/13 09:10AM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 11/10/13 09:39AM
  Re: Stock Peugeot 103 Tuning!!Re: Brandon Compton Brandon Compton 06/20/12 06:42PM
  Re: Stock Peugeot 103 Tuning!!Re: jumpsuit steve jumpsuit steve 07/07/12 05:40PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/16/12 03:56PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/16/12 11:54PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 07/17/12 09:58AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/17/12 11:29AM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 07/17/12 11:39AM
  Re: Stock Peugeot 103 Tuning!!Re: [\/] |=| [\/] |=| 07/23/14 02:44AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/17/12 11:31AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/17/12 05:00PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/18/12 06:59PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/18/12 11:49PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/19/12 10:23AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/19/12 12:53PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/19/12 12:59PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/19/12 04:09PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/21/12 02:05PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/22/12 12:40AM
  Re: Stock Peugeot 103 Tuning!!Re: CtpEDsHED . CtpEDsHED . 07/22/12 09:46AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/22/12 03:57PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/23/12 11:39AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/24/12 11:45AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/24/12 03:01PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 07/24/12 03:36PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/24/12 03:47PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 07/24/12 03:59PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/26/12 12:33AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/26/12 09:51AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/26/12 10:55AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/26/12 10:56AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/26/12 01:09PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/26/12 02:08PM
  Re: Stock Peugeot 103 Tuning!!Re: Aeron Jackson Aeron Jackson 08/03/12 01:11PM
  Re: Stock Peugeot 103 Tuning!!Re: mit mortso mit mortso 08/03/12 02:35PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 08/03/12 03:36PM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 08/04/12 12:30AM
  Re: Stock Peugeot 103 Tuning!!Re: Rachel LGN Rachel LGN 08/09/12 02:47AM
  Re: Stock Peugeot 103 Tuning!!Re: Kevin Hurt Kevin Hurt 01/16/13 09:12PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 01/16/13 10:31PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 01/16/13 11:07PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 01/16/13 11:20PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 01/16/13 11:38PM
  Re: Stock Peugeot 103 Tuning!!Re: Kevin Hurt Kevin Hurt 01/16/13 11:40PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 01/16/13 11:46PM
  Re: Stock Peugeot 103 Tuning!!Re: cheetahchrome . cheetahchrome . 01/17/13 12:12AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 01/18/13 04:13PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 01/18/13 04:27PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 01/18/13 04:28PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 01/18/13 05:36PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 01/18/13 08:08PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/06/13 02:05AM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 08/06/13 08:26AM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/06/13 02:32PM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 08/06/13 03:27PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 08/06/13 08:37PM
  Re: Stock Peugeot 103 Tuning!!Re: cj cj cj cj 08/12/13 01:55PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/06/13 04:57PM
  Re: Stock Peugeot 103 Tuning!!Re: Dirty30 Dillon Dirty30 Dillon 08/06/13 05:21PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/06/13 06:23PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/10/13 03:14AM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 08/11/13 09:00AM
  Re: Stock Peugeot 103 Tuning!!Re: roadent$ craig roadent$ craig 08/11/13 10:14AM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/12/13 10:25AM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 08/12/13 10:37AM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 08/12/13 11:11AM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/12/13 11:28AM
  Re: Stock Peugeot 103 Tuning!!Re: Brad Olivier Brad Olivier 08/12/13 11:39AM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 08/12/13 12:13PM
  Re: Stock Peugeot 103 Tuning!!Re: Nathan Schmidt Nathan Schmidt 08/12/13 05:22PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 08/12/13 05:38PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 08/12/13 06:06PM
  Re: Stock Peugeot 103 Tuning!!Re: Max Allana Max Allana 10/05/15 06:51PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 10/05/15 07:57PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/13/13 10:06AM
  Re: Stock Peugeot 103 Tuning!!Re: david s david s 11/09/13 12:18PM
  Re: Stock Peugeot 103 Tuning!!Re: Nathan Schmidt Nathan Schmidt 12/23/13 06:54PM
  Re: Stock Peugeot 103 Tuning!!Re: Steven Dewaele Steven Dewaele 12/24/13 04:11AM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 12/24/13 08:49AM
  Re: Stock Peugeot 103 Tuning!!Re: Steven Dewaele Steven Dewaele 12/24/13 09:09AM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 12/24/13 10:29AM
  Re: Stock Peugeot 103 Tuning!!Re: Steven Dewaele Steven Dewaele 12/24/13 12:54PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 01/03/14 09:53PM
  Re: Stock Peugeot 103 Tuning!!Re: Nestor Aquino Nestor Aquino 01/02/14 06:27PM
  Re: Stock Peugeot 103 Tuning!!Re: french gimiks french gimiks 01/03/14 09:29PM
  Re: Stock Peugeot 103 Tuning!!Re: Sal RVA mopeds LLC Sal RVA mopeds LLC 03/18/14 01:51AM
  Re: Stock Peugeot 103 Tuning!!Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 03/18/14 05:00AM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 03/18/14 10:04AM
  Re: Stock Peugeot 103 Tuning!!Re: Bobby G Bobby G 03/18/14 05:06PM
  Re: Stock Peugeot 103 Tuning!!Re: Sal RVA mopeds LLC Sal RVA mopeds LLC 08/01/14 02:53PM
  Re: Stock Peugeot 103 Tuning!!Re: The Real Mike D The Real Mike D 08/02/14 11:40AM
  Re: Stock Peugeot 103 Tuning!!Re: Sal RVA mopeds LLC Sal RVA mopeds LLC 08/06/14 01:44AM
  Re: Stock Peugeot 103 Tuning!!Re: Dirty30 Dillon Dirty30 Dillon 08/06/14 09:37AM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 08/06/14 09:40AM
  Re: Stock Peugeot 103 Tuning!!Re: Sal RVA mopeds LLC Sal RVA mopeds LLC 08/07/14 01:17AM
  Re: Stock Peugeot 103 Tuning!!Re: kevin - kevin - 10/20/14 09:49PM
  Re: Stock Peugeot 103 Tuning!!Re: Kevin Hurt Kevin Hurt 10/20/14 11:33PM
  Re: Stock Peugeot 103 Tuning!!Re: Mopedicures Pedals4show Mopedicures Pedals4show 10/16/15 05:28PM
  Re: Stock Peugeot 103 Tuning!!Re: Mopedicures Pedals4show Mopedicures Pedals4show 10/16/15 07:40PM
  Re: Stock Peugeot 103 Tuning!!Re: Narro *UPJET* Narro *UPJET* 06/08/16 05:16AM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 06/08/16 09:07AM
  Re: Stock Peugeot 103 Tuning!!Re: Narro *UPJET* Narro *UPJET* 06/10/16 02:44PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 06/10/16 02:51PM
  Re: Stock Peugeot 103 Tuning!!Re: Narro *UPJET* Narro *UPJET* 06/11/16 03:56PM
  Re: Stock Peugeot 103 Tuning!!Re: Narro *UPJET* Narro *UPJET* 06/08/16 05:37AM
  Re: Stock Peugeot 103 Tuning!!Re: Toledo Riot Toledo Riot 10/03/19 10:46AM
