Re: Stock Peugeot 103 Tuning!!
SABAT! andDestroy /
I'm in. This peugeot has been giving me nightmares.
I knew enough to replace a few things on my inital dig while it was up on the bench.
Ignition.. ripped that pos ignition coil off. Puch coil on there with the brass spacers that come on the stator under. Used the blk wire for ignition, kill and kept red for light switch horn deleted the brown wire, rectifier, resister coils, and brake switches. Have a metric suzuki ignition timing tool, a must have for you french fucks. Dialed tdc, backed off 2mm then advanced. 02... 1.8 dead on, took me a few tries to get it on right but whatevers . I put a bosch h/t coil and external condensor on that bracket infront of the crank sprocket. ignition has been solid since besides a bad boot and a few fouled plugs because of it.
Variator was frozen. with cheetahs writeup I rebuilt it a few time's. Unfroze it greased it good. I lost 3 balls and replaced the weights with 4 m8 nuts a 4 m5 washers with the 4 screws holding em down n blue loctight. This worked good, but during more rebuilds I fucked up the coller and one of the plastic tang spacers is fucked and I stepped on the weird 4 prong spring ship that holds the pressure plate. I'm not fucking. With it until I find some free or cheep parts. It works ok, weights are good. Need to shave em, doesent look like its closing fully, and since I broke that spring n spacer, doesent slip much.
I bought that wide fox belt. Its too wide but works good, seems to get you more gearing.
There's more
Carb modded 14:12 stock intake tomos reeds de restricted exhaust blah blah my phones gonna die so I post again later.
  Stock Peugeot 103 Tuning!!Topic by: Charlie BUZZARD Charlie BUZZARD 06/12/12 11:03AM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 06/12/12 11:12AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 06/12/12 11:19AM
  Re: Stock Peugeot 103 Tuning!!Re: Marvin Chan Marvin Chan 06/12/12 12:24PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 06/19/12 09:45PM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 06/20/12 10:18AM
  Re: Stock Peugeot 103 Tuning!!Re: Rebel Moby Rebel Moby 06/20/12 11:46AM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 06/20/12 12:36PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 06/20/12 12:42PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 06/20/12 02:05PM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 06/20/12 06:02PM
  Re: Stock Peugeot 103 Tuning!!Re: Mel Dyer Mel Dyer 06/20/12 06:24PM
  Re: Stock Peugeot 103 Tuning!!Re: Rachel LGN Rachel LGN 07/16/12 01:47PM
  Re: Stock Peugeot 103 Tuning!!Re: kyle uhl kyle uhl 01/18/13 02:38PM
  Re: Stock Peugeot 103 Tuning!!Re: Steven Dewaele Steven Dewaele 11/10/13 08:31AM
  Re: Stock Peugeot 103 Tuning!!Re: Dirty30 Dillon Dirty30 Dillon 11/10/13 09:10AM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 11/10/13 09:39AM
  Re: Stock Peugeot 103 Tuning!!Re: Brandon Compton Brandon Compton 06/20/12 06:42PM
  Re: Stock Peugeot 103 Tuning!!Re: jumpsuit steve jumpsuit steve 07/07/12 05:40PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/16/12 03:56PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/16/12 11:54PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 07/17/12 09:58AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/17/12 11:29AM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 07/17/12 11:39AM
  Re: Stock Peugeot 103 Tuning!!Re: [\/] |=| [\/] |=| 07/23/14 02:44AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/17/12 11:31AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/17/12 05:00PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/18/12 06:59PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/18/12 11:49PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/19/12 10:23AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/19/12 12:53PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/19/12 12:59PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/19/12 04:09PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/21/12 02:05PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/22/12 12:40AM
  Re: Stock Peugeot 103 Tuning!!Re: CtpEDsHED . CtpEDsHED . 07/22/12 09:46AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/22/12 03:57PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/23/12 11:39AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/24/12 11:45AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/24/12 03:01PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 07/24/12 03:36PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/24/12 03:47PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 07/24/12 03:59PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/26/12 12:33AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/26/12 09:51AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/26/12 10:55AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/26/12 10:56AM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 07/26/12 01:09PM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 07/26/12 02:08PM
  Re: Stock Peugeot 103 Tuning!!Re: Aeron Jackson Aeron Jackson 08/03/12 01:11PM
  Re: Stock Peugeot 103 Tuning!!Re: mit mortso mit mortso 08/03/12 02:35PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 08/03/12 03:36PM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 08/04/12 12:30AM
  Re: Stock Peugeot 103 Tuning!!Re: Rachel LGN Rachel LGN 08/09/12 02:47AM
  Re: Stock Peugeot 103 Tuning!!Re: Kevin Hurt Kevin Hurt 01/16/13 09:12PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 01/16/13 10:31PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 01/16/13 11:07PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 01/16/13 11:20PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 01/16/13 11:38PM
  Re: Stock Peugeot 103 Tuning!!Re: Kevin Hurt Kevin Hurt 01/16/13 11:40PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 01/16/13 11:46PM
  Re: Stock Peugeot 103 Tuning!!Re: cheetahchrome . cheetahchrome . 01/17/13 12:12AM
  Re: Stock Peugeot 103 Tuning!!Re: SABAT! andDestroy SABAT! andDestroy 01/18/13 04:13PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 01/18/13 04:27PM
  Re: Stock Peugeot 103 Tuning!!Re: Charlie BUZZARD Charlie BUZZARD 01/18/13 04:28PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 01/18/13 05:36PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 01/18/13 08:08PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/06/13 02:05AM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 08/06/13 08:26AM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/06/13 02:32PM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 08/06/13 03:27PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 08/06/13 08:37PM
  Re: Stock Peugeot 103 Tuning!!Re: cj cj cj cj 08/12/13 01:55PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/06/13 04:57PM
  Re: Stock Peugeot 103 Tuning!!Re: Dirty30 Dillon Dirty30 Dillon 08/06/13 05:21PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/06/13 06:23PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/10/13 03:14AM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 08/11/13 09:00AM
  Re: Stock Peugeot 103 Tuning!!Re: roadent$ craig roadent$ craig 08/11/13 10:14AM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/12/13 10:25AM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 08/12/13 10:37AM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 08/12/13 11:11AM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/12/13 11:28AM
  Re: Stock Peugeot 103 Tuning!!Re: Brad Olivier Brad Olivier 08/12/13 11:39AM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 08/12/13 12:13PM
  Re: Stock Peugeot 103 Tuning!!Re: Nathan Schmidt Nathan Schmidt 08/12/13 05:22PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 08/12/13 05:38PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 08/12/13 06:06PM
  Re: Stock Peugeot 103 Tuning!!Re: Max Allana Max Allana 10/05/15 06:51PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 10/05/15 07:57PM
  Re: Stock Peugeot 103 Tuning!!Re: M∆®†Y Køk€š M∆®†Y Køk€š 08/13/13 10:06AM
  Re: Stock Peugeot 103 Tuning!!Re: david s david s 11/09/13 12:18PM
  Re: Stock Peugeot 103 Tuning!!Re: Nathan Schmidt Nathan Schmidt 12/23/13 06:54PM
  Re: Stock Peugeot 103 Tuning!!Re: Steven Dewaele Steven Dewaele 12/24/13 04:11AM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 12/24/13 08:49AM
  Re: Stock Peugeot 103 Tuning!!Re: Steven Dewaele Steven Dewaele 12/24/13 09:09AM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 12/24/13 10:29AM
  Re: Stock Peugeot 103 Tuning!!Re: Steven Dewaele Steven Dewaele 12/24/13 12:54PM
  Re: Stock Peugeot 103 Tuning!!Re: M-Tenn Aaron M-Tenn Aaron 01/03/14 09:53PM
  Re: Stock Peugeot 103 Tuning!!Re: Nestor Aquino Nestor Aquino 01/02/14 06:27PM
  Re: Stock Peugeot 103 Tuning!!Re: french gimiks french gimiks 01/03/14 09:29PM
  Re: Stock Peugeot 103 Tuning!!Re: Sal RVA mopeds LLC Sal RVA mopeds LLC 03/18/14 01:51AM
  Re: Stock Peugeot 103 Tuning!!Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 03/18/14 05:00AM
  Re: Stock Peugeot 103 Tuning!!Re: Graham Motzing Graham Motzing 03/18/14 10:04AM
  Re: Stock Peugeot 103 Tuning!!Re: Bobby G Bobby G 03/18/14 05:06PM
  Re: Stock Peugeot 103 Tuning!!Re: Sal RVA mopeds LLC Sal RVA mopeds LLC 08/01/14 02:53PM
  Re: Stock Peugeot 103 Tuning!!Re: The Real Mike D The Real Mike D 08/02/14 11:40AM
  Re: Stock Peugeot 103 Tuning!!Re: Sal RVA mopeds LLC Sal RVA mopeds LLC 08/06/14 01:44AM
  Re: Stock Peugeot 103 Tuning!!Re: Dirty30 Dillon Dirty30 Dillon 08/06/14 09:37AM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 08/06/14 09:40AM
  Re: Stock Peugeot 103 Tuning!!Re: Sal RVA mopeds LLC Sal RVA mopeds LLC 08/07/14 01:17AM
  Re: Stock Peugeot 103 Tuning!!Re: kevin - kevin - 10/20/14 09:49PM
  Re: Stock Peugeot 103 Tuning!!Re: Kevin Hurt Kevin Hurt 10/20/14 11:33PM
  Re: Stock Peugeot 103 Tuning!!Re: Mopedicures Pedals4show Mopedicures Pedals4show 10/16/15 05:28PM
  Re: Stock Peugeot 103 Tuning!!Re: Mopedicures Pedals4show Mopedicures Pedals4show 10/16/15 07:40PM
  Re: Stock Peugeot 103 Tuning!!Re: Narro *UPJET* Narro *UPJET* 06/08/16 05:16AM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 06/08/16 09:07AM
  Re: Stock Peugeot 103 Tuning!!Re: Narro *UPJET* Narro *UPJET* 06/10/16 02:44PM
  Re: Stock Peugeot 103 Tuning!!Re: Matt Madden Matt Madden 06/10/16 02:51PM
  Re: Stock Peugeot 103 Tuning!!Re: Narro *UPJET* Narro *UPJET* 06/11/16 03:56PM
  Re: Stock Peugeot 103 Tuning!!Re: Narro *UPJET* Narro *UPJET* 06/08/16 05:37AM
  Re: Stock Peugeot 103 Tuning!!Re: Toledo Riot Toledo Riot 10/03/19 10:46AM
