Florida gear setup 14-35?
Michael Peditto /
Totally flat where I ride, just set up Maxi Luxe with 70cc TCCD kit, 15mm carb, techno boss pipe. Need to know what gearing to use. From what I have read, my stock 16:45 will shred my crank. I am looking to keep a little acceleration but have more top end speed while keeping the rpm's and temp low.
So if I am right a 14-35 setup should do the trick.
Is this a good gear ratio for the low rpm/temp with higher top end speed?
