Okay so I'm quite undecided on my next step for my little baby, here's a pic of her
Engine wise, she has:
Airsal 65cc kit
Top performances after-market crank
High compression head
All new seals/gaskets/bearings
Dellorto PHBG 19mm
Manifold to suit said carb
Doppler Venturi II Air filter
Tecno circuit exhaust
And soon arriving is my HPI ignition kit.
Now just as important as power, is the handling.
Emphasis here is on ultra ultra light weight and razor sharp handling...
I've already improved upon the original spec by:
Adding Cafe bars
Removing speedo
Removing horn
Removing centre-stand
Removing side panels
Longer seat
Moved footpegs (Mounted to rear shocks)
New shocks with preload adjustment
What would you do next guys? :)
