for those who have done the puch ktm clutch what is the taper on those? similar to puch or similar to minarelli? also they're really cheap on ebay. is that right? are they only $30 or are those cheapo clones? slotted pads vs dots? (edited)
Cheap from china
Yeah, the goofballs making them used to spam them here. Someone finally tried one out and they were complete garbage. The taper didn't sit flush, and the pad segments broke.
Oh, but to answer your question in partial, the taper on the real KTM (at least the one that I have) is the same as the Puch.
Puch is a 6 degree taper. A guy at an instrument shop measured a real KTM clutch taper and it's 6 degrees as well, although he said he would be more willing to bet that it's 5.75 degrees.
Either way, several people have run them without problems on puch cranks without modifying either taper.
Bumping. how can you tell a real KTM from a cheapo clone? what do they usually go for?
if the taper is same/ similar as puch. im thinking about flipping it and cutting new taper to fit a v1 crank. (edited)
I don't know if people have cut the taper, but I'd check it out before throwing on a lathe. I think the center is some sort of hardened steel.
If you can file it, you can turn it
Which clutch above was tried and broke? I wouldn't mind trying the other one to see if it's any better. I may even just use it for the center/hardware and machine new shoes to use mcmaster friction material designed for the ID of a puch clutch bell.
I think the last picture posted was the first version from the company making them, and the second is their improved copy. Definitely don't use the orange one, but maybe they improved things with their latter design.
Here's the original thread: http://www.mopedarmy.com/forums/read.php?7,2108915
"Frank" is what the dude from China who used to spam the forums called himself FYI. (edited)
Yep, see this thread: http://www.mopedarmy.com/forums/read.php?7,2107361,page=3
I can get a very special clutch and they are very very costly and made for the v1's. Looks like a ktm but with a smaller taper.
