mikuni or mikuni clone
what is the difference in the mikuni vm 20mm and the mikuni vm 20mm clone?
Re: mikuni or mikuni clone
"clone"
That's the difference. (edited)
Josh Hall /
yes clone.
mikuni VM 20mm CLONE round slide carburetor - bolt on
look at the reviews on treats for the clones. idle jets the same , main jets you have to use oko jets i think and grind them down to make them fit. also clone doesn`t have quick change main jet.
the other difference is it's cheap. So if you want a good reliable fast and tunable carb, go legit mik. but if you just need something to get a bike up and running the clones work.
altho at that point just get an OKO, they're solid
