added idler pulleys, top pix @ idle, bottom pix rev.
easily undone, 2 words: belt slap
looking for feedback please.
this is for a problem i've been chasing a while
Does it eliminate the belt slap? If so, good job.
I like. I wonder what RPM those bearings spin at? I remember this being an issue when I had a similar idea. I couldn't seem to get off my ass and try it though.
Good idea if it doesn't put too much pressure/load on the crank. Just a thought.
fuckin' glenn, yall should see his coffee mug
I think the spring in the rear Grande pulley would keep it from putting to much stress on the crank.
i can't find the video of a variated M/C on a dyno, you could really see the waveform build up in the belt, nature of the beast i think.
i did the motor mount mod, removed the riveted plate to allow belt adjustment.
tech: i used VW timing belt idler pulleys, free if you know where to scrounge
35mm long bolt, stacked flat and 1 lock washer, plenty of room to the tire.
on the stand, i see very little of the prior belt oscillations, need time to do a full 2 pulley review, running with 1 didn't impress me.
not a spoiler, this is the precursor r&d to a mod that may change... alot.
i just need to "get off my ass and try it though."
