Minarelli Clutch in an E50.
Luke “Funkenet” Hosfield /
How can I get my V1 clutch to work in my E50?
Re: Minarelli Clutch in an E50.
Wave your hands over it and pour two stroke around it.
I have a 9 iron and a table vice. We'll make this work.
a lathe.
Salsa Salsa /
Its easy. Gotta adampt your clutch gears on the bells.
the taper on the v1 clutch is different then the e50 crank, will need to cut a wider taper.
Morini clutch would be .. very close on the taper.
Yep, and you may be able to find those white "god penis" springs, they super tight.
