Re: Chain + Sprockets
tyler pisch /
For maximum blast, 31t front, 20t rear. 70+cc kit recommended. (Very similar to 18x36 gearing on an E50 Puch).
For maximum fun around town, 27t front 22t rear. Pretty much the defacto gearing setup for most Tomos bikes. Still super easy to climb up hills, and headroom for about 53mph up top without breaking anything.
22t is the best rear sprocket and easiest to do. You can get a 20t, but be warned: you will have to take a dremel to your rear wheel and/or turn it down on a lathe or mill. it's time consuming, and only really gives you room for 4more mph or so at the same RPM.
