1977 Pacer throttle
I changed the gas and cleaned the carb but when I try te. o go full throttle my moped will die. any ideas?
Re: 1977 Pacer throttle
Andrew Squiggman /
do you have your airbox attatched? if not you need to go bigger on your jet, or build a box to restrict airflow a bit. try covering your carb a bit with your hand as you rev it up. if that works, thats your problem.
Ryan Najor /
It'll go full throttle when I'm not sititng on it but when I get on it and try to go full throttle it'll just die
Andrew Squiggman /
again, is your airbox attatched?
Ryan Najor /
Where does it attach to
Andrew Squiggman /
your carburetor
Ryan Najor /
Yeah I took that off and cleaned it
Andrew Squiggman /
did you totally disassemble your carb, and clean out every passage and piece and orifice spotless?
Ryan Najor /
Not every piece
Andrew Squiggman /
there is step one
