Re: Trail Tech Regulator Rectifier + 12v light coil = FAIL
Marc Friedman /
Fantastic write up and i am sure to try all the positions of the non floating position. do i need to attempt this on multiple set ups to be sure it is working correctly? Should I seek permission from My primary ignition coil or is it in the interest of science to forge ahead without consensus?
Now I got ahold of an hpi "2 ten" cdi which is their new 20 w light coil but it has only one hot wire. And the coil is literally encased in epoxy. So I read it as a grounded 12v ac system. So am I correct in thinking that in fact 50% of its potential energy is already disappearing into the frame?
Now with the remaining output. We were going to funnel it into a two wire trail tech with one wire to ground and the other to both the 20 watt light coil and to one side of a silicon rectifier. The other half of the Input to the silicon rectifier connects to ground. the opposite side of the silicon rectifier goes one lead to negative side of a small battery and the other to the positive lead of the battery. Then all the non ignition energy is fed from the neg terminal of the battery and all the electrons return to the positive side ie a floating d/c. I see this as inferior to the above but the only alternative. Do the experts agree?
If I put a flasher relay in would the flasher be before or after the bulbs that will be affected and is it spliced in with one end hot and the other end directly to the positive terminal?
  Trail Tech Regulator Rectifier + 12v light coil = FAILTopic by: Deadped Ryan Deadped Ryan 06/01/12 10:13PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/01/12 10:29PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JBOT Admin JBOT Admin 06/01/12 10:40PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/02/12 04:02PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/02/12 11:06PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/02/12 11:11PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JBOT Admin JBOT Admin 06/02/12 11:18PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/02/12 11:33PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JBOT Admin JBOT Admin 06/02/12 11:54PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Michael Mike Naz Michael Mike Naz 06/03/12 02:22AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/03/12 11:19AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JBOT Admin JBOT Admin 06/03/12 01:02PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/04/12 04:54PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Jake P Jake P 06/04/12 05:35PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/04/12 06:45PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Jake P Jake P 06/04/12 06:50PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/04/12 08:26PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Jake P Jake P 06/04/12 08:55PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/04/12 09:51PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JBOT Admin JBOT Admin 06/04/12 10:21PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/04/12 11:03PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/05/12 09:55AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/05/12 11:46AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/05/12 01:03PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/05/12 01:13PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/05/12 01:39PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/05/12 01:42PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/05/12 03:19PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/05/12 03:52PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/05/12 04:00PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/05/12 04:04PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/05/12 05:08PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/05/12 06:00PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/05/12 06:50PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/05/12 07:09PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/05/12 07:25PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/05/12 07:44PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/05/12 08:06PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Jesse Stephenson Jesse Stephenson 06/05/12 08:46PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/05/12 09:06PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/05/12 09:08PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/05/12 09:17PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/06/12 11:05AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/06/12 03:45PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/06/12 02:23PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/06/12 03:04PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/06/12 03:59PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Graham Motzing Graham Motzing 06/06/12 04:26PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/06/12 04:41PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/08/12 10:16PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/11/12 06:42PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/11/12 11:57PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Magnus Burkal Magnus Burkal 04/03/13 08:41AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/12/12 10:01AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/12/12 02:53PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Young Austin Young Austin 06/13/12 01:36AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 04/03/13 10:12AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 04/03/13 02:35PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Max (ツ) Max (ツ) 04/03/13 10:51AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Marc Friedman Marc Friedman 04/03/13 03:23PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 04/03/13 06:59PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 04/03/13 07:09PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 04/03/13 08:17PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Marc Friedman Marc Friedman 04/03/13 08:02PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Marc Friedman Marc Friedman 04/03/13 08:13PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Marc Friedman Marc Friedman 04/03/13 08:24PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 04/03/13 08:46PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 04/03/13 10:28PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/03/13 11:12PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Marc Friedman Marc Friedman 04/04/13 12:16AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 04/04/13 12:30AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/26/13 12:43AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/26/13 12:52AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 06/26/13 12:00PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/26/13 05:35PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/26/13 05:58PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/26/13 08:20PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 06/26/13 09:24PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 06/26/13 09:46PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/26/13 10:14PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 06/26/13 10:36PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/28/13 12:07AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 06/28/13 01:32AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/28/13 12:13PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/28/13 08:54PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 06/28/13 09:10PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/30/13 12:40PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 06/30/13 01:19PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/30/13 02:24PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/30/13 03:11PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 07/01/13 11:23AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 07/01/13 12:09PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/01/13 12:36PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Scooterbike G Scooterbike G 07/01/13 02:33PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/01/13 03:19PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 07/02/13 02:49AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Scooterbike G Scooterbike G 07/02/13 07:21AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/02/13 10:11AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Scooterbike G Scooterbike G 07/02/13 10:25AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/02/13 10:55AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Scooterbike G Scooterbike G 07/02/13 11:34AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 07/02/13 06:12PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JR H JR H 07/03/13 04:09AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 07/03/13 10:45AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 07/03/13 11:52AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Scooterbike G Scooterbike G 07/03/13 01:02PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/03/13 01:25PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: *.* HONDA *.* HONDA 07/03/13 05:53PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JR H JR H 07/03/13 09:58PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/03/13 06:04PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/03/13 10:07PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JR H JR H 07/03/13 10:41PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/04/13 02:03AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JR H JR H 07/04/13 02:45AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/04/13 12:23AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JR H JR H 07/04/13 02:10AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 07/05/13 01:15AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JR H JR H 07/05/13 04:07AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/05/13 11:01AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JR H JR H 07/05/13 12:12PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/05/13 12:50PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/05/13 01:41PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JR H JR H 07/05/13 08:08PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 07/05/13 08:18PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: garridan robinett garridan robinett 07/06/13 06:17PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: 5 Strings 5 Strings 07/06/13 07:05PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/05/13 08:59PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 07/06/13 03:42PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: S Kubik S Kubik 07/06/13 04:00PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Marc Friedman Marc Friedman 10/19/13 09:24PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Jake P Jake P 10/20/13 01:53AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 10/19/13 10:12PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Marc Friedman Marc Friedman 10/21/13 12:53PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 10/21/13 01:36PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Born to be WillD Born to be WillD 10/21/13 02:00PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 10/21/13 07:28PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 10/22/13 09:29AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 03/01/14 09:14PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 03/02/14 04:02PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 03/02/14 07:36PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Kurt Van Luven Kurt Van Luven 04/27/20 04:53AM
