Re: Trail Tech Regulator Rectifier + 12v light coil = FAIL
Deadped Ryan /
I'm probably just going to stick with two phase since I've already invested in a $44 regulator/rectifier for two phase rectification. I might wire in the low coil with a separate unregulated rectifier but probably not unless I need it... 6 wires coming under the flywheel is pushing what will fit.
I was looking at the chokes, and I think I'm going to try and get by with just the caps. Out of curiosity though, would the original 6v light coil be a good choke? It is after all an inductance coil and does have a ferrous center... Ya know... if I need it ;)
Aja, Wayne can be impatient, resulting in ass-ish qualities. It probably would've helped if you read some of the stuff he linked and posted - then asked questions. That's just how it is.
  Trail Tech Regulator Rectifier + 12v light coil = FAILTopic by: Deadped Ryan Deadped Ryan 06/01/12 10:13PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/01/12 10:29PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JBOT Admin JBOT Admin 06/01/12 10:40PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/02/12 04:02PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/02/12 11:06PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/02/12 11:11PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JBOT Admin JBOT Admin 06/02/12 11:18PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/02/12 11:33PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JBOT Admin JBOT Admin 06/02/12 11:54PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Michael Mike Naz Michael Mike Naz 06/03/12 02:22AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/03/12 11:19AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JBOT Admin JBOT Admin 06/03/12 01:02PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/04/12 04:54PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Jake P Jake P 06/04/12 05:35PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/04/12 06:45PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Jake P Jake P 06/04/12 06:50PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/04/12 08:26PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Jake P Jake P 06/04/12 08:55PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/04/12 09:51PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JBOT Admin JBOT Admin 06/04/12 10:21PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/04/12 11:03PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/05/12 09:55AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/05/12 11:46AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/05/12 01:03PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/05/12 01:13PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/05/12 01:39PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/05/12 01:42PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/05/12 03:19PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/05/12 03:52PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/05/12 04:00PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/05/12 04:04PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/05/12 05:08PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/05/12 06:00PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/05/12 06:50PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/05/12 07:09PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/05/12 07:25PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/05/12 07:44PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/05/12 08:06PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Jesse Stephenson Jesse Stephenson 06/05/12 08:46PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/05/12 09:06PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/05/12 09:08PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/05/12 09:17PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/06/12 11:05AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/06/12 03:45PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/06/12 02:23PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/06/12 03:04PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/06/12 03:59PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Graham Motzing Graham Motzing 06/06/12 04:26PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/06/12 04:41PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/08/12 10:16PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/11/12 06:42PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/11/12 11:57PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Magnus Burkal Magnus Burkal 04/03/13 08:41AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Keaton D. Keaton D. 06/12/12 10:01AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/12/12 02:53PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Young Austin Young Austin 06/13/12 01:36AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 04/03/13 10:12AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 04/03/13 02:35PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Max (ツ) Max (ツ) 04/03/13 10:51AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Marc Friedman Marc Friedman 04/03/13 03:23PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 04/03/13 06:59PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 04/03/13 07:09PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 04/03/13 08:17PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Marc Friedman Marc Friedman 04/03/13 08:02PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Marc Friedman Marc Friedman 04/03/13 08:13PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Marc Friedman Marc Friedman 04/03/13 08:24PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 04/03/13 08:46PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 04/03/13 10:28PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/03/13 11:12PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Marc Friedman Marc Friedman 04/04/13 12:16AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 04/04/13 12:30AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/26/13 12:43AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/26/13 12:52AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 06/26/13 12:00PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/26/13 05:35PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/26/13 05:58PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/26/13 08:20PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 06/26/13 09:24PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 06/26/13 09:46PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/26/13 10:14PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 06/26/13 10:36PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/28/13 12:07AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 06/28/13 01:32AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/28/13 12:13PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/28/13 08:54PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 06/28/13 09:10PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/30/13 12:40PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 06/30/13 01:19PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 06/30/13 02:24PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 06/30/13 03:11PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 07/01/13 11:23AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 07/01/13 12:09PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/01/13 12:36PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Scooterbike G Scooterbike G 07/01/13 02:33PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/01/13 03:19PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 07/02/13 02:49AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Scooterbike G Scooterbike G 07/02/13 07:21AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/02/13 10:11AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Scooterbike G Scooterbike G 07/02/13 10:25AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/02/13 10:55AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Scooterbike G Scooterbike G 07/02/13 11:34AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 07/02/13 06:12PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JR H JR H 07/03/13 04:09AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Neil Burgess Neil Burgess 07/03/13 10:45AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 07/03/13 11:52AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Scooterbike G Scooterbike G 07/03/13 01:02PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/03/13 01:25PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: *.* HONDA *.* HONDA 07/03/13 05:53PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JR H JR H 07/03/13 09:58PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/03/13 06:04PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/03/13 10:07PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JR H JR H 07/03/13 10:41PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/04/13 02:03AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JR H JR H 07/04/13 02:45AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/04/13 12:23AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JR H JR H 07/04/13 02:10AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 07/05/13 01:15AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JR H JR H 07/05/13 04:07AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/05/13 11:01AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JR H JR H 07/05/13 12:12PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/05/13 12:50PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/05/13 01:41PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: JR H JR H 07/05/13 08:08PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 07/05/13 08:18PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: garridan robinett garridan robinett 07/06/13 06:17PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: 5 Strings 5 Strings 07/06/13 07:05PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 07/05/13 08:59PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 07/06/13 03:42PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: S Kubik S Kubik 07/06/13 04:00PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Marc Friedman Marc Friedman 10/19/13 09:24PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Jake P Jake P 10/20/13 01:53AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 10/19/13 10:12PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Marc Friedman Marc Friedman 10/21/13 12:53PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 10/21/13 01:36PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Born to be WillD Born to be WillD 10/21/13 02:00PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Ryan . Ryan . 10/21/13 07:28PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 10/22/13 09:29AM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 03/01/14 09:14PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Deadped Ryan Deadped Ryan 03/02/14 04:02PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 03/02/14 07:36PM
  Re: Trail Tech Regulator Rectifier + 12v light coil = FAILRe: Kurt Van Luven Kurt Van Luven 04/27/20 04:53AM
