Re: Fuel Mileage with Larger Carbs?
Vincent Hill /
Because of this input, I have decided to either get the 19 MM Racing Dellorto or 17.5 Dellorto PHVA.
I am going to mount this in the Stock intake AFTER I widen the inlet to match the Carb ID. Yes, I know this is not the perfect solution but until I see an Intake Manifold of the correct size with smooth bends it will have to do. Also the Venturi Effect of fast air being restricted then released should speed up the fuel Ram effect (At least that is my hope). If it runs like Crap I will remove it until I can either buy or make what I want.
I like the idea of the electric Choke but the Fuel Bowel looks like it will not fit and I do not know if I can swap my fuel bowel on the 17.5
The 19 Racing also has issues, 2 as I can see the adjustments are on the left side vs the Right side on the stock. Second, it looks like I will need to modify the CHoke and install a cable or some kind of operating device.
Any suggestions?
  Fuel Mileage with Larger Carbs?Topic by: Vincent Hill Vincent Hill 06/01/12 11:18AM
  Re: Fuel Mileage with Larger Carbs?Re: Probably Fred Probably Fred 06/01/12 01:21PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 02:44PM
  Re: Fuel Mileage with Larger Carbs?Re: Hugh Janus Hugh Janus 06/01/12 02:46PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 03:08PM
  Re: Fuel Mileage with Larger Carbs?Re: . (Nick) . (Nick) 06/01/12 03:13PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 03:52PM
  Re: Fuel Mileage with Larger Carbs?Re: nick s nick s 06/01/12 04:02PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 04:39PM
  Re: Fuel Mileage with Larger Carbs?Re: Probably Fred Probably Fred 06/01/12 04:03PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 04:53PM
  Re: Fuel Mileage with Larger Carbs?Re: not a Baron Asshole not a Baron Asshole 06/01/12 04:44PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 04:58PM
  Re: Fuel Mileage with Larger Carbs?Re: Probably Fred Probably Fred 06/01/12 05:03PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 05:08PM
  Re: Fuel Mileage with Larger Carbs?Re: RingringBANG ! RingringBANG ! 06/01/12 05:11PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 05:23PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 05:25PM
  Re: Fuel Mileage with Larger Carbs?Re: nick s nick s 06/01/12 09:50PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/02/12 09:56PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/01/12 10:59PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/02/12 10:08PM
  Re: Fuel Mileage with Larger Carbs?Re: Frank Horrigan Frank Horrigan 06/03/12 02:33AM
  Re: Fuel Mileage with Larger Carbs?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 06/03/12 01:19PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/03/12 01:38PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/04/12 01:25PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/04/12 01:33PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/05/12 11:02AM
  Re: Fuel Mileage with Larger Carbs?Re: Salsa Salsa Salsa Salsa 06/03/12 02:08PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/04/12 01:16PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/04/12 01:28PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/05/12 10:47AM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/05/12 12:20PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/06/12 11:21AM
  Re: Fuel Mileage with Larger Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/07/12 12:43PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/07/12 01:08PM
  Re: Fuel Mileage with Larger Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/07/12 06:41PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/08/12 10:41AM
  Re: Fuel Mileage with Larger Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/08/12 01:16PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/11/12 01:44PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 07/16/12 03:16PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 07/31/12 05:04PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 04:59PM
  Re: Fuel Mileage with Larger Carbs?Re: Born to be WillD Born to be WillD 06/06/12 11:45AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/06/12 04:14PM
  Re: Fuel Mileage with Larger Carbs?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 06/07/12 02:17AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 02:52AM
  Re: Fuel Mileage with Larger Carbs?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 06/07/12 10:22AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 05:02PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/07/12 12:32PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 05:07PM
  Re: Fuel Mileage with Larger Carbs?Re: Probably Fred Probably Fred 06/07/12 06:34PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/08/12 10:37AM
  Re: Fuel Mileage with Larger Carbs?Re: Max (ツ) Max (ツ) 08/01/12 11:55AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 08/01/12 12:33PM
  Re: Fuel Mileage with Larger Carbs?Re: Matt Madden Matt Madden 08/02/12 11:14AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 08/02/12 01:57PM
  Re: Fuel Mileage with Larger Carbs?Re: Matt Madden Matt Madden 08/03/12 11:09AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 08/03/12 02:09PM
  Re: Fuel Mileage with Larger Carbs?Re: Salsa Salsa Salsa Salsa 06/04/12 01:35PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 05:18PM
