Re: Fuel Mileage with Larger Carbs?
Vincent Hill /
Flagrant - Wrote:
> Yep just more generous porting but also aluminum
> cylinders pass heat through much better. A piston
> porter will have less gas mileage at lower rpm
> because of the dreaded 'blow back' but get the rpm
> up and the would be blow back doesn't have time to
> make its exit. And not only is it aluminum but
> the cooling fin area is very good by moped
> standards
No Arguments here! I remember when Yamaha used a Chrome Bore in the cylinders as opposed to Steel lined aluminum cylinders and then when Nikasil came out it was the Cats Meow! At the end of a race the entire sides of the bike would be covered with pre-mix from the blow back caused by the slow corners! I "WILL" work this out and because of better power need less throttle position which should be a stand off on the fuel mileage!
Now just waiting for MLM to make a fully bent tube intake as opposed to the (Very nicely done but straight tube welded) intake by Weekends
  Fuel Mileage with Larger Carbs?Topic by: Vincent Hill Vincent Hill 06/01/12 11:18AM
  Re: Fuel Mileage with Larger Carbs?Re: Probably Fred Probably Fred 06/01/12 01:21PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 02:44PM
  Re: Fuel Mileage with Larger Carbs?Re: Hugh Janus Hugh Janus 06/01/12 02:46PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 03:08PM
  Re: Fuel Mileage with Larger Carbs?Re: . (Nick) . (Nick) 06/01/12 03:13PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 03:52PM
  Re: Fuel Mileage with Larger Carbs?Re: nick s nick s 06/01/12 04:02PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 04:39PM
  Re: Fuel Mileage with Larger Carbs?Re: Probably Fred Probably Fred 06/01/12 04:03PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 04:53PM
  Re: Fuel Mileage with Larger Carbs?Re: not a Baron Asshole not a Baron Asshole 06/01/12 04:44PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 04:58PM
  Re: Fuel Mileage with Larger Carbs?Re: Probably Fred Probably Fred 06/01/12 05:03PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 05:08PM
  Re: Fuel Mileage with Larger Carbs?Re: RingringBANG ! RingringBANG ! 06/01/12 05:11PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 05:23PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 05:25PM
  Re: Fuel Mileage with Larger Carbs?Re: nick s nick s 06/01/12 09:50PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/02/12 09:56PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/01/12 10:59PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/02/12 10:08PM
  Re: Fuel Mileage with Larger Carbs?Re: Frank Horrigan Frank Horrigan 06/03/12 02:33AM
  Re: Fuel Mileage with Larger Carbs?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 06/03/12 01:19PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/03/12 01:38PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/04/12 01:25PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/04/12 01:33PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/05/12 11:02AM
  Re: Fuel Mileage with Larger Carbs?Re: Salsa Salsa Salsa Salsa 06/03/12 02:08PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/04/12 01:16PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/04/12 01:28PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/05/12 10:47AM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/05/12 12:20PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/06/12 11:21AM
  Re: Fuel Mileage with Larger Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/07/12 12:43PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/07/12 01:08PM
  Re: Fuel Mileage with Larger Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/07/12 06:41PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/08/12 10:41AM
  Re: Fuel Mileage with Larger Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/08/12 01:16PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/11/12 01:44PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 07/16/12 03:16PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 07/31/12 05:04PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 04:59PM
  Re: Fuel Mileage with Larger Carbs?Re: Born to be WillD Born to be WillD 06/06/12 11:45AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/06/12 04:14PM
  Re: Fuel Mileage with Larger Carbs?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 06/07/12 02:17AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 02:52AM
  Re: Fuel Mileage with Larger Carbs?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 06/07/12 10:22AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 05:02PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/07/12 12:32PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 05:07PM
  Re: Fuel Mileage with Larger Carbs?Re: Probably Fred Probably Fred 06/07/12 06:34PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/08/12 10:37AM
  Re: Fuel Mileage with Larger Carbs?Re: Max (ツ) Max (ツ) 08/01/12 11:55AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 08/01/12 12:33PM
  Re: Fuel Mileage with Larger Carbs?Re: Matt Madden Matt Madden 08/02/12 11:14AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 08/02/12 01:57PM
  Re: Fuel Mileage with Larger Carbs?Re: Matt Madden Matt Madden 08/03/12 11:09AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 08/03/12 02:09PM
  Re: Fuel Mileage with Larger Carbs?Re: Salsa Salsa Salsa Salsa 06/04/12 01:35PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 05:18PM
