Re: Fuel Mileage with Larger Carbs?
Flagrant - /
You are up against the wall wanting both fuel economy and power. This is why dual stage carbs were developed for cars. If you really want to pursue this the most practical route for the mopeder would be to have two carbs progressively activated or seperately activated. One quite small and one large. Better atomization and metering at low/mid rpm in the smaller carb is a big part of it. If you are going single carb consider that a reed inducted engine with good porting can use a smaller carb. I suggested the Mikuni 16mm ^^^ as a compromise for the better atomization of the Mikuni and still make pretty good rpm. I really feel though that dual carbs will give you the most dreamy ride and I think you will see more of this in the future at least among the more wacko of us.
  Fuel Mileage with Larger Carbs?Topic by: Vincent Hill Vincent Hill 06/01/12 11:18AM
  Re: Fuel Mileage with Larger Carbs?Re: Probably Fred Probably Fred 06/01/12 01:21PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 02:44PM
  Re: Fuel Mileage with Larger Carbs?Re: Hugh Janus Hugh Janus 06/01/12 02:46PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 03:08PM
  Re: Fuel Mileage with Larger Carbs?Re: . (Nick) . (Nick) 06/01/12 03:13PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 03:52PM
  Re: Fuel Mileage with Larger Carbs?Re: nick s nick s 06/01/12 04:02PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 04:39PM
  Re: Fuel Mileage with Larger Carbs?Re: Probably Fred Probably Fred 06/01/12 04:03PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 04:53PM
  Re: Fuel Mileage with Larger Carbs?Re: not a Baron Asshole not a Baron Asshole 06/01/12 04:44PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 04:58PM
  Re: Fuel Mileage with Larger Carbs?Re: Probably Fred Probably Fred 06/01/12 05:03PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 05:08PM
  Re: Fuel Mileage with Larger Carbs?Re: RingringBANG ! RingringBANG ! 06/01/12 05:11PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 05:23PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 05:25PM
  Re: Fuel Mileage with Larger Carbs?Re: nick s nick s 06/01/12 09:50PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/02/12 09:56PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/01/12 10:59PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/02/12 10:08PM
  Re: Fuel Mileage with Larger Carbs?Re: Frank Horrigan Frank Horrigan 06/03/12 02:33AM
  Re: Fuel Mileage with Larger Carbs?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 06/03/12 01:19PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/03/12 01:38PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/04/12 01:25PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/04/12 01:33PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/05/12 11:02AM
  Re: Fuel Mileage with Larger Carbs?Re: Salsa Salsa Salsa Salsa 06/03/12 02:08PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/04/12 01:16PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/04/12 01:28PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/05/12 10:47AM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/05/12 12:20PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/06/12 11:21AM
  Re: Fuel Mileage with Larger Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/07/12 12:43PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/07/12 01:08PM
  Re: Fuel Mileage with Larger Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/07/12 06:41PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/08/12 10:41AM
  Re: Fuel Mileage with Larger Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/08/12 01:16PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/11/12 01:44PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 07/16/12 03:16PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 07/31/12 05:04PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 04:59PM
  Re: Fuel Mileage with Larger Carbs?Re: Born to be WillD Born to be WillD 06/06/12 11:45AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/06/12 04:14PM
  Re: Fuel Mileage with Larger Carbs?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 06/07/12 02:17AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 02:52AM
  Re: Fuel Mileage with Larger Carbs?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 06/07/12 10:22AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 05:02PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/07/12 12:32PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 05:07PM
  Re: Fuel Mileage with Larger Carbs?Re: Probably Fred Probably Fred 06/07/12 06:34PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/08/12 10:37AM
  Re: Fuel Mileage with Larger Carbs?Re: Max (ツ) Max (ツ) 08/01/12 11:55AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 08/01/12 12:33PM
  Re: Fuel Mileage with Larger Carbs?Re: Matt Madden Matt Madden 08/02/12 11:14AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 08/02/12 01:57PM
  Re: Fuel Mileage with Larger Carbs?Re: Matt Madden Matt Madden 08/03/12 11:09AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 08/03/12 02:09PM
  Re: Fuel Mileage with Larger Carbs?Re: Salsa Salsa Salsa Salsa 06/04/12 01:35PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 05:18PM
