Re: Fuel Mileage with Larger Carbs?
Vincent Hill /
Ken Roff Wrote:
> Right ^^ 2 strokes get horrible mpg with big
> carbs
> My 17 ft boat with a 3cyl 85hp engine got 4 mpg at
> 22-23 knots (25 mph)but at WOT got less then
> 2mpg.
> Your 250cc Ninja though a 4 stroke would get half
> the mpg it gets if you went or could go WOT all
> the time.
> I get much better city Mpg or better all round mph
> if I'm going on 35 mph roads.
> Just yesterday "I went around the block" (12 mi)
> on state route with my hand twisted all down for
> more then half the trip. When I got back I added
> almost 1/2 gallon of mix to top off my magnum's
> tank.
> Yikes I can't afford the 3+ gallons of premium and
> synthetic oil mix a week just to ride a hr a day.
> I'm gonna have to put 19mm carbs on all my bikes
> though the Gila bikes love 24mm carbs though.
> I like stock 100mpg bikes but where I live after I
> get out of my development they're kinda dangerous
> and I really could only go north/northwest
> South and east have hi speed roads and several
> steep hills.
> To blast you got to pay I guess.
Yes, it is the Compromise between what you can live with and what the cost are. I knew I needed about 50 MPH to be safe (Just in Washington DC) because the Max speed is about 45 MPH. Most of the streets are 25 so 35 is needed and the Legal Limit for Mopeds on "Level" Ground. WHen I am on state routes in Virginia by the Pentagon and the SPeed Limit is 45 and the Police will pull you over at 46 MPH I am close to maxed out at 45.
SO I am going to a 22 tooth rear for a 50 MPH Top SPeed and cruise at 40 to 45 and first try the 19 MM Carb. I saw the Weekends Manifold which was a lot of straight tubing cut angled and welded for a good fit but I want a Bent tube like MLM Usually makes for a smooth flow but do not want the carb sticking out the side to avoid the issues when I am in the Rain!
  Fuel Mileage with Larger Carbs?Topic by: Vincent Hill Vincent Hill 06/01/12 11:18AM
  Re: Fuel Mileage with Larger Carbs?Re: Probably Fred Probably Fred 06/01/12 01:21PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 02:44PM
  Re: Fuel Mileage with Larger Carbs?Re: Hugh Janus Hugh Janus 06/01/12 02:46PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 03:08PM
  Re: Fuel Mileage with Larger Carbs?Re: . (Nick) . (Nick) 06/01/12 03:13PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 03:52PM
  Re: Fuel Mileage with Larger Carbs?Re: nick s nick s 06/01/12 04:02PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 04:39PM
  Re: Fuel Mileage with Larger Carbs?Re: Probably Fred Probably Fred 06/01/12 04:03PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 04:53PM
  Re: Fuel Mileage with Larger Carbs?Re: not a Baron Asshole not a Baron Asshole 06/01/12 04:44PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 04:58PM
  Re: Fuel Mileage with Larger Carbs?Re: Probably Fred Probably Fred 06/01/12 05:03PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 05:08PM
  Re: Fuel Mileage with Larger Carbs?Re: RingringBANG ! RingringBANG ! 06/01/12 05:11PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 05:23PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/01/12 05:25PM
  Re: Fuel Mileage with Larger Carbs?Re: nick s nick s 06/01/12 09:50PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/02/12 09:56PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/01/12 10:59PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/02/12 10:08PM
  Re: Fuel Mileage with Larger Carbs?Re: Frank Horrigan Frank Horrigan 06/03/12 02:33AM
  Re: Fuel Mileage with Larger Carbs?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 06/03/12 01:19PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/03/12 01:38PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/04/12 01:25PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/04/12 01:33PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/05/12 11:02AM
  Re: Fuel Mileage with Larger Carbs?Re: Salsa Salsa Salsa Salsa 06/03/12 02:08PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/04/12 01:16PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/04/12 01:28PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/05/12 10:47AM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/05/12 12:20PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/06/12 11:21AM
  Re: Fuel Mileage with Larger Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/07/12 12:43PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/07/12 01:08PM
  Re: Fuel Mileage with Larger Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/07/12 06:41PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/08/12 10:41AM
  Re: Fuel Mileage with Larger Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/08/12 01:16PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/11/12 01:44PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 07/16/12 03:16PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 07/31/12 05:04PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 04:59PM
  Re: Fuel Mileage with Larger Carbs?Re: Born to be WillD Born to be WillD 06/06/12 11:45AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/06/12 04:14PM
  Re: Fuel Mileage with Larger Carbs?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 06/07/12 02:17AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 02:52AM
  Re: Fuel Mileage with Larger Carbs?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 06/07/12 10:22AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 05:02PM
  Re: Fuel Mileage with Larger Carbs?Re: Flagrant - Flagrant - 06/07/12 12:32PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 05:07PM
  Re: Fuel Mileage with Larger Carbs?Re: Probably Fred Probably Fred 06/07/12 06:34PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/08/12 10:37AM
  Re: Fuel Mileage with Larger Carbs?Re: Max (ツ) Max (ツ) 08/01/12 11:55AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 08/01/12 12:33PM
  Re: Fuel Mileage with Larger Carbs?Re: Matt Madden Matt Madden 08/02/12 11:14AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 08/02/12 01:57PM
  Re: Fuel Mileage with Larger Carbs?Re: Matt Madden Matt Madden 08/03/12 11:09AM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 08/03/12 02:09PM
  Re: Fuel Mileage with Larger Carbs?Re: Salsa Salsa Salsa Salsa 06/04/12 01:35PM
  Re: Fuel Mileage with Larger Carbs?Re: Vincent Hill Vincent Hill 06/07/12 05:18PM
