SMOKE?!?!
Puch Maxi e50 , long story short, cleansed my carb. had trouble with it leaking, tweaked a few things(it stopped).. drained all the old fuel. filled a full tank of bel-ray 2T (synthetic) , got er' started up and sounding good. but there is ALOT of blue smoke from the pipe, and its stinky. I did 40:1 mix, (128oz gas per 3.2oz oil)
common with this oil or what??
Re: SMOKE?!?!
Probably Fred /
Could be blown crank seal and your burning trans fluid or you put the choke plate in wrong not clipping it on to the choke lever
Re: SMOKE?!?!
hmmm.. took it around the block and it has diminished alot... and it is running wayyyyyyy better than before.
Re: SMOKE?!?!
just a little richer than before maybe?? the smoke is fairly blue in color.
Re: SMOKE?!?!
Eric Boucher /
The transmission fluid makes white smoke, not blue....
Correct me if I am wrong.
Re: SMOKE?!?!
Probably Fred /
Not if you run motor oil in it instead of type f.
Type f is so 70's. For the 21st century 0-20w synthetic is used
I've been running oil in my e50's and za50"s for many years
Re: SMOKE?!?!
well... after a short bit of riding the smoke has stopped totally, and with the new mix of gas/oil, cleaned carb/jet, the bike is running amazing.. very psyched!
Re: SMOKE?!?!
Cleats Onionpockets /
Had the bike been sitting for a long time without running? Could be you just needed to burn off the gunk in the pipe.
Re: SMOKE?!?!
it hadnt been sitting for than a week or so.. im just guessing it was something to do with draining the old fuel and changing up the oil type and the mix..
Re: SMOKE?!?!
Lucky, I want blue smoke so thick people think i'm running from the smoke monster from LOST
Re: SMOKE?!?!
^same
Re: SMOKE?!?!
Scottee doesn't know. /
