Puch CDI lighting woes
Nikolas Sanow /
So I installed what is essentially the treats Puch CDI adventure pack v2.
Strong spark, bike runs great UNLESS I actually run the lighting coil.
As soon as I connect the lighting coil to the regulator I can only rev about 1/4th turn on the throttle before it starts losing power and coughing. It doesn't make sense to me as the lighting coil is completely independent of the power coil. We measured the output from the lighting coil and were getting readings of 30V+, and when hooked up to the regulator we were still getting readings of 20V+.
Of course this completely destroys 12V bulbs, but that really doesn't even matter while the lighting coil is somehow affecting the power.
We grounded everything to completely separate grounding points, tried two different regulators, checked the stator plate for any exposed wires arcing or weird wiring setups and found nothing. Used a junction box, connected wires directly, disconnected lights completely. Still no luck.
As long as i've got just the cdi to stator connected, the bike runs as it should. I just can't commute with no lights. Any ideas?
  Puch CDI lighting woesTopic by: Nikolas Sanow Nikolas Sanow 05/29/12 04:59PM
  Re: Puch CDI lighting woesRe: Deadped Ryan Deadped Ryan 05/29/12 06:19PM
  Re: Puch CDI lighting woesRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/29/12 06:40PM
  Re: Puch CDI lighting woesRe: Nikolas Sanow Nikolas Sanow 05/29/12 07:07PM
  Re: Puch CDI lighting woesRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/29/12 07:22PM
  Re: Puch CDI lighting woesRe: JOE PEG JOE PEG 05/29/12 07:36PM
  Re: Puch CDI lighting woesRe: Nikolas Sanow Nikolas Sanow 05/29/12 07:52PM
  Re: Puch CDI lighting woesRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/29/12 10:34PM
  Re: Puch CDI lighting woesRe: Nikolas Sanow Nikolas Sanow 05/29/12 10:44PM
  Re: Puch CDI lighting woesRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/29/12 10:46PM
  Re: Puch CDI lighting woesRe: Jesse Stephenson Jesse Stephenson 05/29/12 08:40PM
  Re: Puch CDI lighting woesRe: Nikolas Sanow Nikolas Sanow 05/29/12 10:42PM
  Re: Puch CDI lighting woesRe: Deadped Ryan Deadped Ryan 05/30/12 02:06PM
  Re: Puch CDI lighting woesRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/30/12 02:36PM
  Re: Puch CDI lighting woesRe: Jesse Stephenson Jesse Stephenson 05/30/12 02:55PM
  Re: Puch CDI lighting woesRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/30/12 03:09PM
  Re: Puch CDI lighting woesRe: Jesse Stephenson Jesse Stephenson 05/30/12 03:52PM
  Re: Puch CDI lighting woesRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/30/12 04:08PM
  Re: Puch CDI lighting woesRe: Jesse Stephenson Jesse Stephenson 05/30/12 06:36PM
  Re: Puch CDI lighting woesRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/30/12 06:54PM
  Re: Puch CDI lighting woesRe: Totally normal JBOT Totally normal JBOT 05/29/12 08:49PM
  Re: Puch CDI lighting woesRe: cj cj cj cj 05/29/12 08:54PM
  Re: Puch CDI lighting woesRe: Jesse Stephenson Jesse Stephenson 05/29/12 10:55PM
  Re: Puch CDI lighting woesRe: Totally normal JBOT Totally normal JBOT 05/29/12 11:26PM
  Re: Puch CDI lighting woesRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/29/12 11:32PM
  Re: Puch CDI lighting woesRe: JOE PEG JOE PEG 05/30/12 03:46AM
  Re: Puch CDI lighting woesRe: JOE PEG JOE PEG 05/30/12 04:03AM
  Re: Puch CDI lighting woesRe: JOE PEG JOE PEG 05/30/12 04:53AM
  Re: Puch CDI lighting woesRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/30/12 05:47AM
  Re: Puch CDI lighting woesRe: Nikolas Sanow Nikolas Sanow 05/30/12 06:29AM
  Re: Puch CDI lighting woesRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/30/12 07:45AM
  Re: Puch CDI lighting woesRe: Nikolas Sanow Nikolas Sanow 05/30/12 03:23PM
  Re: Puch CDI lighting woesRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/30/12 03:27PM
  Re: Puch CDI lighting woesRe: Jesse Stephenson Jesse Stephenson 05/30/12 12:56PM
  Re: Puch CDI lighting woesRe: Jesse Stephenson Jesse Stephenson 05/30/12 07:36PM
  Re: Puch CDI lighting woesRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/30/12 08:59PM
  Re: Puch CDI lighting woesRe: Jesse Stephenson Jesse Stephenson 05/30/12 09:13PM
  Re: Puch CDI lighting woesRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/30/12 09:28PM
  Re: Puch CDI lighting woesRe: Jesse Stephenson Jesse Stephenson 05/31/12 12:18PM
  Re: Puch CDI lighting woesRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/31/12 12:51PM
  Re: Puch CDI lighting woesRe: Jesse Stephenson Jesse Stephenson 05/31/12 02:40PM
  Re: Puch CDI lighting woesRe: Josh G Josh G 05/31/12 02:50PM
  Re: Puch CDI lighting woesRe: Nikolas Sanow Nikolas Sanow 05/31/12 03:28PM
  Re: Puch CDI lighting woesRe: JOE PEG JOE PEG 05/31/12 04:34PM
  Re: Puch CDI lighting woesRe: Charlie BUZZARD Charlie BUZZARD 05/31/12 03:22PM
  Re: Puch CDI lighting woesRe: Probably Fred Probably Fred 05/31/12 03:33PM
  Re: Puch CDI lighting woesRe: Jesse Stephenson Jesse Stephenson 05/31/12 03:40PM
  Re: Puch CDI lighting woesRe: Jimbo Grand Daddy Jimbo Grand Daddy 05/31/12 07:28PM
  Re: Puch CDI lighting woesRe: Nikolas Sanow Nikolas Sanow 05/31/12 06:28PM
  Re: Puch CDI lighting woesRe: Jesse Stephenson Jesse Stephenson 05/31/12 06:37PM
  Re: Puch CDI lighting woesRe: Flagrant - Flagrant - 05/31/12 04:44PM
  Re: Puch CDI lighting woesRe: Deadped Ryan Deadped Ryan 05/31/12 05:04PM
  Re: Puch CDI lighting woesRe: Nathan Hobart Nathan Hobart 05/31/12 05:10PM
  Re: Puch CDI lighting woesRe: Nathan Hobart Nathan Hobart 05/31/12 05:14PM
  Re: Puch CDI lighting woesRe: Josh G Josh G 05/31/12 07:44PM
  Re: Puch CDI lighting woesRe: Deadped Ryan Deadped Ryan 06/01/12 12:33AM
  Re: Puch CDI lighting woesRe: Jesse Stephenson Jesse Stephenson 06/01/12 01:15AM
  Re: Puch CDI lighting woesRe: Jesse Stephenson Jesse Stephenson 07/09/12 05:03PM
  Re: Puch CDI lighting woesRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/09/12 06:15PM
  Re: Puch CDI lighting woesRe: Jesse Stephenson Jesse Stephenson 07/09/12 06:25PM
  Re: Puch CDI lighting woesRe: Jesse Stephenson Jesse Stephenson 07/10/12 05:12PM
