Upgrading Carb/Intake Manifold/Air Filter/Exhaust questions
Wouldntyou Wannaknow /
I have a 12mm Bing Carb (with 12mm intake) and I'm looking to upgrade that to a 15mm Bing Carb and 15mm intake manifold. In company with that, I also want to upgrade the Air Filter and Exhaust, which I have to do if I'm upgrading the Carb, right? I guess I'm asking for recommendations on Exhausts and Air Filters that perform well and are going to fit well (I don't want to have to do much alteration.) I have a stock Puch Magnum XK--and I'm wondering how much more speed I will get after doing these alterations.
All of those things will work fine with the rest of my stock engine, right?
Lastly, how is this air filter?
https://www.treatland.tv/puch-bing-red-foam-hi-flow-filter-p/puch-bing-red-foam-air-filter.htm
Anyway, thanks for your help in advance.
Re: Upgrading Carb/Intake Manifold/Air Filter/Exhaust questions
Luke “Funkenet” Hosfield /
That filter blows. Get gas on it and it falls apart.
Any suggestions for a better one? I'm willing to get a good one, I just want it to fit well.
Top:
Thought through some things, figured I'd run it by MA before I buy it all.
15mm Bing Carb
15mm Intake Manifold
MLM Putt-Putt Exhaust
Uni Hi-flow Air Filter (the 7 dollar one).
do all of those upgrades make sense in conjunction? and what the hell jet would you guys start out with when tuning? Thanks.
There's no reason that setup shouldn't work out that I can see. IMO the best air filter is a stretched piece of pantyhose and a rubber band.
Haven't run a bing in forever so no idea what size jet. Is the performance tuning spreadsheet still in the wiki? Check it
So, you literally just cover the whole with panty hose and rubber band it up? Sounds cheaper than a air filter, as long as it won't make everything too lean.
it definitely runs lean until you jet it properly
