Re: Malossi Variotop: You're using the wrong belt
Adam Pereira /
Been wrenching soooo much....no posty...best I've found for a 103....Gates 5VX350. It sits lower into the cheek than a BX...even though it's 3mm taller....because maybe the 2 degree difference on the taper of the belt.. I dunno...but it does. And...the teeth of the belt actually touch the hub! What? Yeah.
It's a stiffer belt.. more like a kevlar. Running this with a doppler clutch pulley.
Starting. ...well....if you have decompression it's 100% gonna hook up. For my no decompression malossi 70...still no problem...it will almost turn over just pushing....but what works for me it's to give it a push and get a foot to the lunch lever...boom.. yeah...you have one right? Game changer.
  Malossi Variotop: You're using the wrong beltTopic by: Mars   Mars   05/27/12 07:21PM
  Re: Malossi Variotop: You're using the wrong beltRe: Jake P Jake P 05/27/12 07:24PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   05/27/12 07:29PM
  Re: Malossi Variotop: You're using the wrong beltRe: Jake P Jake P 05/27/12 10:09PM
  Re: Malossi Variotop: You're using the wrong beltRe: Peter Fondue Peter Fondue 05/27/12 07:41PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   05/27/12 07:42PM
  Re: Malossi Variotop: You're using the wrong beltRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/27/12 08:34PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   05/27/12 11:09PM
  Re: Malossi Variotop: You're using the wrong beltRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/27/12 11:25PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 09:54AM
  Re: Malossi Variotop: You're using the wrong beltRe: not a Baron Asshole not a Baron Asshole 09/17/14 03:13PM
  Re: Malossi Variotop: You're using the wrong beltRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/27/12 11:53PM
  Re: Malossi Variotop: You're using the wrong beltRe: Tracy Meade Tracy Meade 07/03/12 11:13AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 11:21AM
  Re: Malossi Variotop: You're using the wrong beltRe: Tracy Meade Tracy Meade 07/03/12 11:16AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 11:22AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 11:27AM
  Re: Malossi Variotop: You're using the wrong beltRe: Graham Motzing Graham Motzing 07/03/12 11:40AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 01:31PM
  Re: Malossi Variotop: You're using the wrong beltRe: *.* HONDA *.* HONDA 07/03/12 05:59PM
  Re: Malossi Variotop: You're using the wrong beltRe: LSLB RXb LSLB RXb 07/03/12 02:28PM
  Re: Malossi Variotop: You're using the wrong beltRe: Graham Motzing Graham Motzing 07/03/12 02:57PM
  Re: Malossi Variotop: You're using the wrong beltRe: Tracy Meade Tracy Meade 07/03/12 03:37PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 04:17PM
  Re: Malossi Variotop: You're using the wrong beltRe: Tracy Meade Tracy Meade 07/03/12 04:20PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 04:37PM
  Re: Malossi Variotop: You're using the wrong beltRe: brian schulz brian schulz 09/17/14 03:27PM
  Re: Malossi Variotop: You're using the wrong beltRe: Adam Pereira Adam Pereira 08/30/16 08:26PM
  Re: Malossi Variotop: You're using the wrong beltRe: cheetahchrome . cheetahchrome . 08/30/16 10:18PM
  Re: Malossi Variotop: You're using the wrong beltRe: Adam Pereira Adam Pereira 08/30/16 10:34PM
  Re: Malossi Variotop: You're using the wrong beltRe: Totally normal JBOT Totally normal JBOT 08/30/16 10:53PM
  Re: Malossi Variotop: You're using the wrong beltRe: Adam Pereira Adam Pereira 08/30/16 10:58PM
  Re: Malossi Variotop: You're using the wrong beltRe: Adam Pereira Adam Pereira 08/31/16 05:13PM
  Re: Malossi Variotop: You're using the wrong beltRe: Poop Wizard Poop Wizard 01/06/22 10:15AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 06:10PM
  Re: Malossi Variotop: You're using the wrong beltRe: Graham Motzing Graham Motzing 07/03/12 10:08PM
