Re: Malossi Variotop: You're using the wrong belt
Graham Motzing /
that is huge!
so are the stock continental or whatever they are called french belts a 30 degree angle? I dont think i have one that isn't all shot to hell... maybe... we would need a nos or low mileage bike to tell.
maybe they expect the variator to just grab the top of the belt and have less contact area=less rolling resistance.
  Malossi Variotop: You're using the wrong beltTopic by: Mars   Mars   05/27/12 07:21PM
  Re: Malossi Variotop: You're using the wrong beltRe: Jake P Jake P 05/27/12 07:24PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   05/27/12 07:29PM
  Re: Malossi Variotop: You're using the wrong beltRe: Jake P Jake P 05/27/12 10:09PM
  Re: Malossi Variotop: You're using the wrong beltRe: Peter Fondue Peter Fondue 05/27/12 07:41PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   05/27/12 07:42PM
  Re: Malossi Variotop: You're using the wrong beltRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/27/12 08:34PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   05/27/12 11:09PM
  Re: Malossi Variotop: You're using the wrong beltRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/27/12 11:25PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 09:54AM
  Re: Malossi Variotop: You're using the wrong beltRe: not a Baron Asshole not a Baron Asshole 09/17/14 03:13PM
  Re: Malossi Variotop: You're using the wrong beltRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/27/12 11:53PM
  Re: Malossi Variotop: You're using the wrong beltRe: Tracy Meade Tracy Meade 07/03/12 11:13AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 11:21AM
  Re: Malossi Variotop: You're using the wrong beltRe: Tracy Meade Tracy Meade 07/03/12 11:16AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 11:22AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 11:27AM
  Re: Malossi Variotop: You're using the wrong beltRe: Graham Motzing Graham Motzing 07/03/12 11:40AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 01:31PM
  Re: Malossi Variotop: You're using the wrong beltRe: *.* HONDA *.* HONDA 07/03/12 05:59PM
  Re: Malossi Variotop: You're using the wrong beltRe: LSLB RXb LSLB RXb 07/03/12 02:28PM
  Re: Malossi Variotop: You're using the wrong beltRe: Graham Motzing Graham Motzing 07/03/12 02:57PM
  Re: Malossi Variotop: You're using the wrong beltRe: Tracy Meade Tracy Meade 07/03/12 03:37PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 04:17PM
  Re: Malossi Variotop: You're using the wrong beltRe: Tracy Meade Tracy Meade 07/03/12 04:20PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 04:37PM
  Re: Malossi Variotop: You're using the wrong beltRe: brian schulz brian schulz 09/17/14 03:27PM
  Re: Malossi Variotop: You're using the wrong beltRe: Adam Pereira Adam Pereira 08/30/16 08:26PM
  Re: Malossi Variotop: You're using the wrong beltRe: cheetahchrome . cheetahchrome . 08/30/16 10:18PM
  Re: Malossi Variotop: You're using the wrong beltRe: Adam Pereira Adam Pereira 08/30/16 10:34PM
  Re: Malossi Variotop: You're using the wrong beltRe: Totally normal JBOT Totally normal JBOT 08/30/16 10:53PM
  Re: Malossi Variotop: You're using the wrong beltRe: Adam Pereira Adam Pereira 08/30/16 10:58PM
  Re: Malossi Variotop: You're using the wrong beltRe: Adam Pereira Adam Pereira 08/31/16 05:13PM
  Re: Malossi Variotop: You're using the wrong beltRe: Poop Wizard Poop Wizard 01/06/22 10:15AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 06:10PM
  Re: Malossi Variotop: You're using the wrong beltRe: Graham Motzing Graham Motzing 07/03/12 10:08PM
