Re: Malossi Variotop: You're using the wrong belt
Mars   /
Glad I'm not the only one!
I heard through the grapevine that ole BigBlockFiero actually had a jig he used to alter his snowmobile belts using a router. I've contacted him to see if he had some tips and tricks; waiting to hear back.
I'm also thinking of contacting Gates directly to see if they have other options with which I'm not already familiar.
Things are actually looking better for me since my custom setup uses a ~35" belt. It looks like one of the 3/4" belts which is available will actually be about right for me, but I will likely have to fabricate a custom pulley in which to install my clutch pulley guts.
  Malossi Variotop: You're using the wrong beltTopic by: Mars   Mars   05/27/12 07:21PM
  Re: Malossi Variotop: You're using the wrong beltRe: Jake P Jake P 05/27/12 07:24PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   05/27/12 07:29PM
  Re: Malossi Variotop: You're using the wrong beltRe: Jake P Jake P 05/27/12 10:09PM
  Re: Malossi Variotop: You're using the wrong beltRe: Peter Fondue Peter Fondue 05/27/12 07:41PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   05/27/12 07:42PM
  Re: Malossi Variotop: You're using the wrong beltRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/27/12 08:34PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   05/27/12 11:09PM
  Re: Malossi Variotop: You're using the wrong beltRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/27/12 11:25PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 09:54AM
  Re: Malossi Variotop: You're using the wrong beltRe: not a Baron Asshole not a Baron Asshole 09/17/14 03:13PM
  Re: Malossi Variotop: You're using the wrong beltRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/27/12 11:53PM
  Re: Malossi Variotop: You're using the wrong beltRe: Tracy Meade Tracy Meade 07/03/12 11:13AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 11:21AM
  Re: Malossi Variotop: You're using the wrong beltRe: Tracy Meade Tracy Meade 07/03/12 11:16AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 11:22AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 11:27AM
  Re: Malossi Variotop: You're using the wrong beltRe: Graham Motzing Graham Motzing 07/03/12 11:40AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 01:31PM
  Re: Malossi Variotop: You're using the wrong beltRe: *.* HONDA *.* HONDA 07/03/12 05:59PM
  Re: Malossi Variotop: You're using the wrong beltRe: LSLB RXb LSLB RXb 07/03/12 02:28PM
  Re: Malossi Variotop: You're using the wrong beltRe: Graham Motzing Graham Motzing 07/03/12 02:57PM
  Re: Malossi Variotop: You're using the wrong beltRe: Tracy Meade Tracy Meade 07/03/12 03:37PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 04:17PM
  Re: Malossi Variotop: You're using the wrong beltRe: Tracy Meade Tracy Meade 07/03/12 04:20PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 04:37PM
  Re: Malossi Variotop: You're using the wrong beltRe: brian schulz brian schulz 09/17/14 03:27PM
  Re: Malossi Variotop: You're using the wrong beltRe: Adam Pereira Adam Pereira 08/30/16 08:26PM
  Re: Malossi Variotop: You're using the wrong beltRe: cheetahchrome . cheetahchrome . 08/30/16 10:18PM
  Re: Malossi Variotop: You're using the wrong beltRe: Adam Pereira Adam Pereira 08/30/16 10:34PM
  Re: Malossi Variotop: You're using the wrong beltRe: Totally normal JBOT Totally normal JBOT 08/30/16 10:53PM
  Re: Malossi Variotop: You're using the wrong beltRe: Adam Pereira Adam Pereira 08/30/16 10:58PM
  Re: Malossi Variotop: You're using the wrong beltRe: Adam Pereira Adam Pereira 08/31/16 05:13PM
  Re: Malossi Variotop: You're using the wrong beltRe: Poop Wizard Poop Wizard 01/06/22 10:15AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 06:10PM
  Re: Malossi Variotop: You're using the wrong beltRe: Graham Motzing Graham Motzing 07/03/12 10:08PM
