Malossi Variotop: You're using the wrong belt
Mars   /
So after a little research, and realization of what should have been obvious, I have come to the conclusion that everyone is using the wrong belt with this variator.
The Variotop is reputed for having a wider range of movement. It does this by using a steeper pulley cheek angle. Pretty much all V-belts are 40 degrees; that being, the angle between the two sides is 40. The angle between the cheeks of the Variotop is 30 degrees.
Now both 77 and Treats sell a BX belt (BX32 for Peugeot for example) for use with the variator, but the BX32 has the 40 degree sides which means that only the top of the belt will make contact with the pulley cheeks; this causes rapid wear and destruction of the belt.
The proper belt to use would be a 5VX315.
I'm curious why I haven't heard of more people having trouble with this.
Here's an example. Below is a BX belt firmly pressed against the cheek on the left side. A ten degree gap can clearly be seen.
(edited)
  Malossi Variotop: You're using the wrong beltTopic by: Mars   Mars   05/27/12 07:21PM
  Re: Malossi Variotop: You're using the wrong beltRe: Jake P Jake P 05/27/12 07:24PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   05/27/12 07:29PM
  Re: Malossi Variotop: You're using the wrong beltRe: Jake P Jake P 05/27/12 10:09PM
  Re: Malossi Variotop: You're using the wrong beltRe: Peter Fondue Peter Fondue 05/27/12 07:41PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   05/27/12 07:42PM
  Re: Malossi Variotop: You're using the wrong beltRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/27/12 08:34PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   05/27/12 11:09PM
  Re: Malossi Variotop: You're using the wrong beltRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/27/12 11:25PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 09:54AM
  Re: Malossi Variotop: You're using the wrong beltRe: not a Baron Asshole not a Baron Asshole 09/17/14 03:13PM
  Re: Malossi Variotop: You're using the wrong beltRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/27/12 11:53PM
  Re: Malossi Variotop: You're using the wrong beltRe: Tracy Meade Tracy Meade 07/03/12 11:13AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 11:21AM
  Re: Malossi Variotop: You're using the wrong beltRe: Tracy Meade Tracy Meade 07/03/12 11:16AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 11:22AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 11:27AM
  Re: Malossi Variotop: You're using the wrong beltRe: Graham Motzing Graham Motzing 07/03/12 11:40AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 01:31PM
  Re: Malossi Variotop: You're using the wrong beltRe: *.* HONDA *.* HONDA 07/03/12 05:59PM
  Re: Malossi Variotop: You're using the wrong beltRe: LSLB RXb LSLB RXb 07/03/12 02:28PM
  Re: Malossi Variotop: You're using the wrong beltRe: Graham Motzing Graham Motzing 07/03/12 02:57PM
  Re: Malossi Variotop: You're using the wrong beltRe: Tracy Meade Tracy Meade 07/03/12 03:37PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 04:17PM
  Re: Malossi Variotop: You're using the wrong beltRe: Tracy Meade Tracy Meade 07/03/12 04:20PM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 04:37PM
  Re: Malossi Variotop: You're using the wrong beltRe: brian schulz brian schulz 09/17/14 03:27PM
  Re: Malossi Variotop: You're using the wrong beltRe: Adam Pereira Adam Pereira 08/30/16 08:26PM
  Re: Malossi Variotop: You're using the wrong beltRe: cheetahchrome . cheetahchrome . 08/30/16 10:18PM
  Re: Malossi Variotop: You're using the wrong beltRe: Adam Pereira Adam Pereira 08/30/16 10:34PM
  Re: Malossi Variotop: You're using the wrong beltRe: Totally normal JBOT Totally normal JBOT 08/30/16 10:53PM
  Re: Malossi Variotop: You're using the wrong beltRe: Adam Pereira Adam Pereira 08/30/16 10:58PM
  Re: Malossi Variotop: You're using the wrong beltRe: Adam Pereira Adam Pereira 08/31/16 05:13PM
  Re: Malossi Variotop: You're using the wrong beltRe: Poop Wizard Poop Wizard 01/06/22 10:15AM
  Re: Malossi Variotop: You're using the wrong beltRe: Mars   Mars   07/03/12 06:10PM
  Re: Malossi Variotop: You're using the wrong beltRe: Graham Motzing Graham Motzing 07/03/12 10:08PM
