amal 15mm carburetor
Charles Morton /
I have a sachs 505a and I am looking at good carbs to put on it would this amal 15 mm carburetor
https://www.treatland.tv/amal-15mm-carburetor-p/amal-carburetor-15mm.htm
Re: amal 15mm carburetor
Great carb. Only thing better is a 15mm phbg. You'll need a riser or custom intake to make it work (as with pretty much everything but the square bing that came stock).
Only downside is jets are $10 each. Great under rated carb. Way better than a 15 bing or 14 sha.
Charles Morton /
Were do you get the riser
I actually made mine from 3/4" aluminum bar stock... I've got a cad drawing and I'm going to try and get them produced and stocked on treats. I've made a couple by hand... just takes me a minute. Shoot me a PM if you'd be interested in one.
yep, amals are great carbs
