80cc Chappy/Champ Yamaha Bore
I have a 77' Yamaha Champ lb 80 (same as chappy 80). Took the cylinder out today and the piston is toast. I believe its a 47mm. There is some wear on the cylinder too as well so i am thinking i should bore it larger and get a bigger piston. I'm a little lost on what I should ask the machine shop and what pistons i could use. I will be upgrading the carb/intake but do i need to change the exhaust as well. Any input/guidance would be appreciated
Re: 80cc Chappy/Champ Yamaha Bore
bump
bump anyone?
