I rode home last night from work on the MB5.
That headlight isn't worth a velvet painting of a whale and a dolphin getting it on.
It is fucking terrible. A strobe light pointed towards the sky would have provided more light! Seriously considering wiring another battery in parallel and that will effectively double my voltage. Then adding a twin headlight setup. It was bad really fucking bad....
I will check it out today. See if anything is loose or the bulb backed out. 10x worse than my last aftermarket headlight.
Glen, Im going to get to removing the clutch cover and checking the gears. Probably this week. I will have some time off for the first time in a few weeks. I have a manual and all your helpful info so I will keep you posted.
