Re: Stock moby 50v mod question r/t blunderbuss
Rebel Moby /
Docking the length of the interior portion of the exit pipe will give you better performance at the expense of noise. Stock the exhause has to double back through the two bulkheads, which will dampen the noise, before it gets to the exit pipe. The longer course and passages it must pass will take away some of the performance.
Best plan for modification on the exhause is to make a new back plate with the larger size exit pipe and then experiment with length. This way of you do not like the results you can go back to stock or make another test pipe for experiments rather then cut up something and then have to mess around with trying to reverse the experimental modifications.
  Stock moby 50v mod question r/t blunderbussTopic by: Rachel LGN Rachel LGN 05/25/12 02:50PM
  Re: Stock moby 50v mod question r/t blunderbussRe: birdsy —— birdsy —— 05/25/12 03:14PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Born to be WillD Born to be WillD 05/25/12 03:45PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rachel LGN Rachel LGN 05/25/12 04:02PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 05/25/12 04:59PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Mel Dyer Mel Dyer 05/25/12 06:06PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rachel LGN Rachel LGN 05/26/12 01:36AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rollo Tomassi Rollo Tomassi 06/04/12 10:16PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rachel LGN Rachel LGN 06/08/12 03:38PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 05/26/12 10:16AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Mel Dyer Mel Dyer 05/26/12 11:52AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 05/26/12 12:08PM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 07/21/13 09:07PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 07/21/13 11:26PM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 07/22/13 12:05AM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 07/22/13 12:23AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 07/22/13 08:50AM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 07/22/13 10:13AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Sean Berg Sean Berg 08/03/13 01:24AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 08/03/13 09:22AM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 08/11/13 07:56PM
