Re: Stock moby 50v mod question r/t blunderbuss
Rebel Moby /
Exhause goes out the blue pipe, all the way back towards the header via the black holes and then exits through the grey pipe. Reversing through the two black holes in the bulkheads is what gives the quiet aspect to the silencer. You can make those bigger as needed. The grey pipe is the one that needs to be enlarged for better exit and less containment or back pressure. That is the pipe you would want to replace with 7/16 or 11mm ID tube. You can experiment with the exact right size by making a blanking plate to replace the plate and long tube and drill a 11mm or 7/16 hole and see how she performs before getting and bending a new inner pipe.
Shortening the inner pipe you are replacing will also have an impact on performance as the route to get out is shorter, but also noisier.
  Stock moby 50v mod question r/t blunderbussTopic by: Rachel LGN Rachel LGN 05/25/12 02:50PM
  Re: Stock moby 50v mod question r/t blunderbussRe: birdsy —— birdsy —— 05/25/12 03:14PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Born to be WillD Born to be WillD 05/25/12 03:45PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rachel LGN Rachel LGN 05/25/12 04:02PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 05/25/12 04:59PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Mel Dyer Mel Dyer 05/25/12 06:06PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rachel LGN Rachel LGN 05/26/12 01:36AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rollo Tomassi Rollo Tomassi 06/04/12 10:16PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rachel LGN Rachel LGN 06/08/12 03:38PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 05/26/12 10:16AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Mel Dyer Mel Dyer 05/26/12 11:52AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 05/26/12 12:08PM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 07/21/13 09:07PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 07/21/13 11:26PM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 07/22/13 12:05AM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 07/22/13 12:23AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 07/22/13 08:50AM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 07/22/13 10:13AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Sean Berg Sean Berg 08/03/13 01:24AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 08/03/13 09:22AM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 08/11/13 07:56PM
