Re: Stock moby 50v mod question r/t blunderbuss
David Gabert /
Hey rebel, so doing the math for a stock AV7 with a dellorto 15.15 carb and a malossi 15mm intake (not port matched) I keep coming up with a starting point of 10.8 or basically 11mm. Now the drilling is where I get a bit confused. I have the two baffled blunderbuss exhaust. So I drill the exit hole where the exit pipe would go when assembled and then drill two extra holes with a 1/8th bit to make more baffling? Or the two baffle holes which I circled in red? Then add a larger piping for the exit?
  Stock moby 50v mod question r/t blunderbussTopic by: Rachel LGN Rachel LGN 05/25/12 02:50PM
  Re: Stock moby 50v mod question r/t blunderbussRe: birdsy —— birdsy —— 05/25/12 03:14PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Born to be WillD Born to be WillD 05/25/12 03:45PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rachel LGN Rachel LGN 05/25/12 04:02PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 05/25/12 04:59PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Mel Dyer Mel Dyer 05/25/12 06:06PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rachel LGN Rachel LGN 05/26/12 01:36AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rollo Tomassi Rollo Tomassi 06/04/12 10:16PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rachel LGN Rachel LGN 06/08/12 03:38PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 05/26/12 10:16AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Mel Dyer Mel Dyer 05/26/12 11:52AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 05/26/12 12:08PM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 07/21/13 09:07PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 07/21/13 11:26PM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 07/22/13 12:05AM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 07/22/13 12:23AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 07/22/13 08:50AM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 07/22/13 10:13AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Sean Berg Sean Berg 08/03/13 01:24AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 08/03/13 09:22AM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 08/11/13 07:56PM
