Re: Stock moby 50v mod question r/t blunderbuss
Rebel Moby /
If you ever see anything french which looks interesting I might be able to give a better english translation then anything online... unless you find my english incoherent then it would be pointless.
Basically you would not want the sum of the hole areas to be less then 60% of the carb cross section area. The stock exhause you are more concerned about derestriction then reflection of the shock wave to give you that wonderful reversion shot to over fill your combustion chamber. There is not much tunable about the exhause length, chamber size or bulkhead location on the blunderbuss.
For sound deadening you would want many small holes to make up the 60%, if you are unconcerned about the sound then just get some goodly holes in the bulkhead.
Focus on the size of the final outlet by experimenting with a block off plate - somewhere around 11mm or 7/16 inch is a goodly size, if you have a 12mm carb. (edited)
  Stock moby 50v mod question r/t blunderbussTopic by: Rachel LGN Rachel LGN 05/25/12 02:50PM
  Re: Stock moby 50v mod question r/t blunderbussRe: birdsy —— birdsy —— 05/25/12 03:14PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Born to be WillD Born to be WillD 05/25/12 03:45PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rachel LGN Rachel LGN 05/25/12 04:02PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 05/25/12 04:59PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Mel Dyer Mel Dyer 05/25/12 06:06PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rachel LGN Rachel LGN 05/26/12 01:36AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rollo Tomassi Rollo Tomassi 06/04/12 10:16PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rachel LGN Rachel LGN 06/08/12 03:38PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 05/26/12 10:16AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Mel Dyer Mel Dyer 05/26/12 11:52AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 05/26/12 12:08PM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 07/21/13 09:07PM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 07/21/13 11:26PM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 07/22/13 12:05AM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 07/22/13 12:23AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 07/22/13 08:50AM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 07/22/13 10:13AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Sean Berg Sean Berg 08/03/13 01:24AM
  Re: Stock moby 50v mod question r/t blunderbussRe: Rebel Moby Rebel Moby 08/03/13 09:22AM
  Re: Stock moby 50v mod question r/t blunderbussRe: David Gabert David Gabert 08/11/13 07:56PM
