Re: Stock mods to improve V1 top speeds
kim jensen /
Hey Luke, yeah when you open the carb up you may need to enlarge the idle hole in the little copper tube in the SHA. Take a leedle large enough to fit into the hole (holes) in it and gently widen the opening slightly. Also make sure your idle screw is turned in - probably all the way.
I haven't been able to test mine much because I need an 11mm cone lock nut on the rear wheel before I can drive it.
I did the piston and cylinder porting mentioned above and on my one test it seemed quite a bit faster than the 25 stock. I only put a 54 jet in it, may need to go bigger. Mine had the super restricted 14-9 with the narrow intake- also now bored to 12mm.
You should be on the right track.
  Stock mods to improve V1 top speedsTopic by: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/15/12 07:54PM
  Re: Stock mods to improve V1 top speedsRe: Jonathan S Jonathan S 05/15/12 08:05PM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/15/12 08:12PM
  Re: Stock mods to improve V1 top speedsRe: Jonathan S Jonathan S 05/15/12 08:36PM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/15/12 08:13PM
  Re: Stock mods to improve V1 top speedsRe: Morgan Aguayo Morgan Aguayo 05/15/12 10:13PM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/16/12 10:25AM
  Re: Stock mods to improve V1 top speedsRe: Morgan Aguayo Morgan Aguayo 05/16/12 12:01PM
  Re: Stock mods to improve V1 top speedsRe: Darrell Gabbard Darrell Gabbard 05/17/12 05:59AM
  Re: Stock mods to improve V1 top speedsRe: SABAT! andDestroy SABAT! andDestroy 05/17/12 09:21AM
  Re: Stock mods to improve V1 top speedsRe: Mo Peds Mo Peds 05/17/12 09:26AM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/17/12 09:31AM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/18/12 01:08PM
  Re: Stock mods to improve V1 top speedsRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 05/18/12 01:16PM
  Re: Stock mods to improve V1 top speedsRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 05/18/12 02:21PM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/18/12 02:27PM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/18/12 02:51PM
  Re: Stock mods to improve V1 top speedsRe: Graham Motzing Graham Motzing 05/18/12 07:39PM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/18/12 11:08PM
  Re: Stock mods to improve V1 top speedsRe: Darrell Gabbard Darrell Gabbard 05/19/12 03:17AM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/20/12 12:46PM
  Re: Stock mods to improve V1 top speedsRe: Mo Peds Mo Peds 05/20/12 02:05PM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/20/12 10:43PM
  Re: Stock mods to improve V1 top speedsRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 05/20/12 10:52PM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/20/12 11:10PM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/20/12 11:24PM
  Re: Stock mods to improve V1 top speedsRe: kim jensen kim jensen 05/21/12 12:25AM
  Re: Stock mods to improve V1 top speedsRe: Mo Peds Mo Peds 05/20/12 11:36PM
  Re: Stock mods to improve V1 top speedsRe: Morgan Aguayo Morgan Aguayo 05/20/12 11:54PM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/21/12 01:06AM
  Re: Stock mods to improve V1 top speedsRe: Morgan Aguayo Morgan Aguayo 05/21/12 01:48AM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/21/12 10:49AM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/22/12 11:05PM
  Re: Stock mods to improve V1 top speedsRe: Darrell Gabbard Darrell Gabbard 05/23/12 02:36AM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/23/12 10:45AM
  Re: Stock mods to improve V1 top speedsRe: Graham Motzing Graham Motzing 05/23/12 04:56PM
  Re: Stock mods to improve V1 top speedsRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 05/25/12 01:14PM
  Re: Stock mods to improve V1 top speedsRe: Marvin Chan Marvin Chan 05/25/12 01:58PM
  Re: Stock mods to improve V1 top speedsRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/26/12 12:57AM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/23/12 05:20PM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/24/12 09:12PM
  Re: Stock mods to improve V1 top speedsRe: Graham Motzing Graham Motzing 05/24/12 10:11PM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/25/12 10:49AM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/25/12 10:59AM
  Re: Stock mods to improve V1 top speedsRe: birdsy —— birdsy —— 05/25/12 11:32AM
  Re: Stock mods to improve V1 top speedsRe: Cole Doubt Cole Doubt 05/25/12 12:30PM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/25/12 12:44PM
  Re: Stock mods to improve V1 top speedsRe: birdsy —— birdsy —— 05/26/12 12:48AM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/26/12 11:09AM
  Re: Stock mods to improve V1 top speedsRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 06/21/12 01:25AM
  Re: Stock mods to improve V1 top speedsRe: birdsy —— birdsy —— 05/25/12 12:47PM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/26/12 01:05PM
  Re: Stock mods to improve V1 top speedsRe: birdsy —— birdsy —— 05/26/12 04:16PM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/26/12 04:23PM
  Re: Stock mods to improve V1 top speedsRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 06/20/12 11:58AM
  Re: Stock mods to improve V1 top speedsRe: birdsy —— birdsy —— 05/26/12 04:36PM
  Re: Stock mods to improve V1 top speedsRe: Derek Vanasse Derek Vanasse 05/29/12 02:56AM
  Re: Stock mods to improve V1 top speedsRe: Nathan Hobart Nathan Hobart 05/29/12 03:34AM
  Re: Stock mods to improve V1 top speedsRe: Mo Peds Mo Peds 05/29/12 09:09AM
  Re: Stock mods to improve V1 top speedsRe: birdsy —— birdsy —— 05/29/12 08:17AM
  Re: Stock mods to improve V1 top speedsRe: Mo Peds Mo Peds 05/29/12 09:15AM
  Re: Stock mods to improve V1 top speedsRe: Graham Motzing Graham Motzing 06/21/12 05:37PM
