Re: advice on an E-50 build
Cooper Hennick /
Low end can mean 2 things:
Low RPM power - Treats reed kit, low rpm pipe like a circuit. Stock gears should get you past 30 easy. Maybe even taller gearing to make it more civilized at cruising speeds. It seems like you want this.
Low speed power - either that^ or high rpm power with lower gearing. If you go this route, your bike will accelerate faster, chug more gas, be more fun, be more annoying, and maybe a performance crank. Treats reed kit and the kstar will do this pretty well with a higher rpm pipe. A bigger carb definitely helps too.
I recommend the treats reed kit, circuit pipe, and stock gears. EDIT: oh yeah and your stock crank will be fine with that. (edited)
  advice on an E-50 buildTopic by: Mike Dee Mike Dee 04/13/12 04:09PM
  Re: advice on an E-50 buildRe: Mike Dee Mike Dee 04/13/12 04:37PM
  Re: advice on an E-50 buildRe: Probably Fred Probably Fred 04/13/12 06:22PM
  Re: advice on an E-50 buildRe: Graham Motzing Graham Motzing 04/14/12 10:14AM
  Re: advice on an E-50 buildRe: Salsa Salsa Salsa Salsa 04/14/12 12:04PM
  Re: advice on an E-50 buildRe: Probably Fred Probably Fred 04/14/12 10:40AM
  Re: advice on an E-50 buildRe: Graham Motzing Graham Motzing 04/14/12 12:08PM
  Re: advice on an E-50 buildRe: Salsa Salsa Salsa Salsa 04/14/12 12:12PM
  Re: advice on an E-50 buildRe: Salsa Salsa Salsa Salsa 04/14/12 02:14PM
  Re: advice on an E-50 buildRe: mit mortso mit mortso 04/14/12 03:47PM
  Re: advice on an E-50 buildRe: Salsa Salsa Salsa Salsa 04/15/12 03:15AM
  Re: advice on an E-50 buildRe: Alex Clark Alex Clark 04/14/12 04:50PM
  Re: advice on an E-50 buildRe: Probably Fred Probably Fred 04/14/12 06:47PM
  Re: advice on an E-50 buildRe: Alex Clark Alex Clark 04/15/12 12:15AM
  Re: advice on an E-50 buildRe: Probably Fred Probably Fred 04/15/12 05:12PM
  Re: advice on an E-50 buildRe: Mike Dee Mike Dee 04/16/12 03:52PM
  Re: advice on an E-50 buildRe: Salsa Salsa Salsa Salsa 04/13/12 04:16PM
  Re: advice on an E-50 buildRe: Corey Livieri Corey Livieri 04/13/12 04:39PM
  Re: advice on an E-50 buildRe: Salsa Salsa Salsa Salsa 04/13/12 11:26PM
  Re: advice on an E-50 buildRe: Mike Dee Mike Dee 04/14/12 02:09PM
  Re: advice on an E-50 buildRe: Cooper Hennick Cooper Hennick 04/14/12 02:29PM
