Decking/Cutting a squish @ home
Max (ツ) /
I used an angle grinder and a dremel to deck and cut a new squish on a treats hi comp head yesterday. proof a little creativity can get the job done. The decking was done nearly the same as cutting the squish. the angle grinder was held in the vice and the head was moved around under the wheel. 120, 220, 320, and 400 grit wet sanding was used to hone it in. Took a little over 1.5mm off the head.
The end result was a huge low end gain. No head leaks at all and no gasket, gasketmaker or spray or anything. just aluminum on aluminum. after the carbide cut, it was grinded and then sanded with 220, 320 and 400 grit.
here's how i cut the squish. the dremel is in the vice and the head rotates on the plug
i forgot to take a final picture before i threw it back on the ped. I'll grab one soon
  Decking/Cutting a squish @ homeTopic by: Max (ツ) Max (ツ) 04/05/12 09:43AM
  Re: Decking/Cutting a squish @ homeRe: Overpriced Parts Overpriced Parts 04/05/12 09:50AM
  Re: Decking/Cutting a squish @ homeRe: Mo Peds Mo Peds 04/05/12 10:14AM
  Re: Decking/Cutting a squish @ homeRe: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 04/05/12 10:46AM
  Re: Decking/Cutting a squish @ homeRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/05/12 11:51AM
  Re: Decking/Cutting a squish @ homeRe: Born to be WillD Born to be WillD 04/06/12 01:48PM
  Re: Decking/Cutting a squish @ homeRe: Flagrant - Flagrant - 04/05/12 12:38PM
  Re: Decking/Cutting a squish @ homeRe: Max (ツ) Max (ツ) 04/05/12 01:33PM
  Re: Decking/Cutting a squish @ homeRe: *.* HONDA *.* HONDA 04/05/12 06:49PM
  Re: Decking/Cutting a squish @ homeRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 04/05/12 06:52PM
  Re: Decking/Cutting a squish @ homeRe: Rachid Z Rachid Z 04/05/12 07:37PM
  Re: Decking/Cutting a squish @ homeRe: Max (ツ) Max (ツ) 04/06/12 12:47AM
  Re: Decking/Cutting a squish @ homeRe: Salsa Salsa Salsa Salsa 04/06/12 07:56AM
  Re: Decking/Cutting a squish @ homeRe: Flagrant - Flagrant - 04/06/12 12:17PM
  Re: Decking/Cutting a squish @ homeRe: Like “Funkenet” Hosfield Like “Funkenet” Hosfield 04/06/12 02:08PM
  Re: Decking/Cutting a squish @ homeRe: Like “Funkenet” Hosfield Like “Funkenet” Hosfield 04/06/12 03:30PM
  Re: Decking/Cutting a squish @ homeRe: nick s nick s 04/06/12 03:46PM
  Re: Decking/Cutting a squish @ homeRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/14/19 11:39PM
  Re: Decking/Cutting a squish @ homeRe: Rica Rivera Rica Rivera 01/16/19 11:56PM
  Re: Decking/Cutting a squish @ homeRe: P D P D 01/17/19 10:30AM
  Re: Decking/Cutting a squish @ homeRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/17/19 11:25AM
  Re: Decking/Cutting a squish @ homeRe: * * * * 01/16/19 02:10PM
  Re: Decking/Cutting a squish @ homeRe: Alan Jackson Alan Jackson 01/17/19 11:47AM
  Re: Decking/Cutting a squish @ homeRe: Alan Jackson Alan Jackson 01/17/19 12:04PM
  Re: Decking/Cutting a squish @ homeRe: Salsa Salsa Salsa Salsa 04/05/12 10:03AM
  Re: Decking/Cutting a squish @ homeRe: Salsa Salsa Salsa Salsa 04/05/12 12:48PM
  Re: Decking/Cutting a squish @ homeRe: Salsa Salsa Salsa Salsa 04/06/12 12:50PM
  Re: Decking/Cutting a squish @ homeRe: Salsa Salsa Salsa Salsa 04/06/12 01:50PM
  Re: Decking/Cutting a squish @ homeRe: Salsa Salsa Salsa Salsa 04/06/12 02:22PM
  Re: Decking/Cutting a squish @ homeRe: Salsa Salsa Salsa Salsa 04/06/12 03:37PM
