Re: Review: Samurai G3 Pipe for Peugeot
John M. /
Low end is relatively poor, but honestly not much worse than the Simonini circuit I was running. It runs rich down low, but that's mainly due to the SHA carb. Still trying to sort that. Either way, you'll need a good variator to take advantage of the pipe. Mid and top end are awesome. I'm hitting 45 mph easy with the 50cc Gila kit (3rd transfer added to the case), 15.15 carb, Polini reeds, Polini spring, Doppler ER3, and 11:59 stock gearing. With the Simonini circuit (everything else basically the same) I could barely hit 38 mph.
