Re: More info on Pietcard cdi boxes, 2013 vs 2041
Graham Motzing /
so i'm back to this project. i had to slap my bike together for a rally and put the points back on, so slapping it together for a rally again i put the Treat CDI and 2041 back on.
I rewired the treat cdi with heavy gauge wire, and ground loopies and potted the connections and nice SHCS hardware with lockwashers and loctite... cool.
Hooked it up, got it running, bam fried the pickup coil... ok whatever.
back to the drawing board, new pickup coil, rewired blah blah, running great retarding awesome ripping hard... bam fried another pickup coil.
frustrated so i pulled the main coil and pickup off the treat plate, and installed the 3055, fired up right away running good with treat flywheel but it was missing and completely broke up on the top end, firing all over the place.
ok, maybe its the treat cdi flywheel, redid it with the OEM flywheel, same thing maybe even worse.
Put the timing light on it and when it does break up it is still firing, but firing exactly 180 out of phase. Breaks up randomly but it is pretty consistently broken up over 6000 rpm. Tried moving the 3055 coil around spacing it out and it doesn't seem to make much difference.
Some people say this is what their 3055's do. Some people say this is what happens when your 2041 fries out.
I'm going to have some EE's at work look at the circuit as soon as i can get a schematic from someone. I'm also going to try running a resistor on the line and see if that helps at all.
I'm also thinking i'll try running the treats CDI box on this guy... maybe the A3202/jog if i can find it anywhere, i know i have one in a box somewhere but fuck if i can find it.
  More info on Pietcard cdi boxes, 2013 vs 2041Topic by: Michael Thomas Michael Thomas 02/09/12 04:23PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 02/09/12 04:44PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 02/09/12 04:45PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/09/12 04:46PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/09/12 04:49PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 02/09/12 05:19PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/09/12 05:25PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 02/09/12 05:31PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 02/09/12 05:32PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 02/09/12 05:29PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/09/12 05:38PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/09/12 05:42PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: LSLB RXb LSLB RXb 02/09/12 08:56PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 02/09/12 10:15PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/10/12 01:22AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Born to be WillD Born to be WillD 02/10/12 11:31AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/10/12 12:07PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/10/12 06:35PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: LSLB RXb LSLB RXb 02/10/12 06:47PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 02/11/12 10:01PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Burntout Swoop Burntout Swoop 02/12/12 10:15AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 02/12/12 10:54AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: LSLB RXb LSLB RXb 02/12/12 11:08AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 02/12/12 11:37AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: LSLB RXb LSLB RXb 02/12/12 11:42AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 02/12/12 02:14PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 02/12/12 02:19PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/12/12 02:32PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 02/12/12 02:32PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Flagrant - Flagrant - 02/12/12 02:34PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 02/12/12 02:35PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: LSLB RXb LSLB RXb 02/12/12 02:54PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: DAM' Fairchild DAM' Fairchild 02/20/12 12:24PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 02/20/12 01:15PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: DAM' Fairchild DAM' Fairchild 02/21/12 09:47AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Cooper Hennick Cooper Hennick 02/21/12 01:21PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mel Dyer Mel Dyer 04/22/13 12:04PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Dan Webber Kastner Dan Webber Kastner 02/21/12 11:19AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: GET REALIZED! BE HERE NOW! GET REALIZED! BE HERE NOW! 02/21/12 11:35AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/21/12 12:01PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 02/21/12 12:17PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: OGvandal MPG OGvandal MPG 02/21/12 02:23PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Adam Bandit Adam Bandit 02/21/12 12:34PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 02/21/12 12:58PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 02/21/12 01:25PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 02/21/12 01:31PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Andy Haldeman Andy Haldeman 02/21/12 09:27PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: not a Baron Asshole not a Baron Asshole 02/22/12 08:39PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Cooper Hennick Cooper Hennick 02/22/12 11:17PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 03/28/12 12:35AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: RingringBANG ! RingringBANG ! 03/28/12 08:41AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 03/28/12 10:27AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: LSLB RXb LSLB RXb 03/28/12 10:48AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 03/28/12 11:02AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 03/28/12 12:12PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 03/28/12 12:40PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 03/28/12 12:51PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/02/12 12:41AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 12/29/12 06:46PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 04/22/13 10:15AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Deadped Ryan Deadped Ryan 04/22/13 10:54AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Deadped Ryan Deadped Ryan 04/22/13 10:57AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Deadped Ryan Deadped Ryan 04/22/13 12:41PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Kevin Bishop Kevin Bishop 04/23/13 12:44AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: kron nelly kron nelly 07/23/13 02:10AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 07/23/13 11:36AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: CtpEDsHED . CtpEDsHED . 07/23/13 02:16PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 08/15/13 12:54PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: LSLB RXb LSLB RXb 08/15/13 08:19PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 08/15/13 11:08PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 08/15/13 11:52PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: LSLB RXb LSLB RXb 08/16/13 12:14AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Erik Protsman Erik Protsman 08/26/13 04:46PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 08/26/13 06:02PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Erik Protsman Erik Protsman 08/26/13 06:39PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 08/26/13 07:56PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: greg waldo greg waldo 08/26/13 11:43PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 08/27/13 12:34AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Eero W Eero W 09/18/13 02:46PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: will warn will warn 09/18/13 03:06PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Eero W Eero W 09/18/13 03:54PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 09/18/13 03:59PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Maciek Dub Maciek Dub 09/18/13 05:55PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: CORN PED CORN PED 07/01/14 04:44PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Dirty30 Dillon Dirty30 Dillon 07/01/14 05:00PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 07/01/14 05:26PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Tony montana Tony montana 07/01/14 07:14PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 05/28/15 04:19PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 05/29/15 11:28AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 05/29/15 12:51PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/29/15 01:41PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: will warn will warn 05/28/15 06:21PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 05/29/15 10:47AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/29/15 12:32PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/29/15 02:00PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 05/29/15 03:00PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: theron ross(ofmc) theron ross(ofmc) 08/18/18 01:58PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Alex Hedrick Alex Hedrick 12/22/18 05:56PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Garelli Master✨ Garelli Master✨ 12/22/18 10:00PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Alex Hedrick Alex Hedrick 12/22/18 10:09PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Tone It Down Tone It Down 07/24/19 06:27PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 07/24/19 09:26PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: * * * * 07/26/19 12:23AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: CORN PED CORN PED 07/01/14 05:10PM
