Re: More info on Pietcard cdi boxes, 2013 vs 2041
Mo Peds /
Ok, I switched out to the pietcard 01 purple coil w/2013 using a cev magneto/flywheel. I did this for pat norris so he can see the ignition curve.
It looks like (didn't measure) a good 3-4mm retarding the correct direction we need to throw the heat into the pipe. I have the stator plate turn as far as you can turn it. You install the purple coil after you mounted and tighted the screws on the stator plate. That is the way I did it. The engine is running the athena/euroclindro 47mm kit.
(edited)
  More info on Pietcard cdi boxes, 2013 vs 2041Topic by: Michael Thomas Michael Thomas 02/09/12 04:23PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 02/09/12 04:44PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 02/09/12 04:45PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/09/12 04:46PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/09/12 04:49PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 02/09/12 05:19PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/09/12 05:25PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 02/09/12 05:31PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 02/09/12 05:32PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 02/09/12 05:29PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/09/12 05:38PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/09/12 05:42PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: LSLB RXb LSLB RXb 02/09/12 08:56PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 02/09/12 10:15PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/10/12 01:22AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Born to be WillD Born to be WillD 02/10/12 11:31AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/10/12 12:07PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/10/12 06:35PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: LSLB RXb LSLB RXb 02/10/12 06:47PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 02/11/12 10:01PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Burntout Swoop Burntout Swoop 02/12/12 10:15AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 02/12/12 10:54AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: LSLB RXb LSLB RXb 02/12/12 11:08AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 02/12/12 11:37AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: LSLB RXb LSLB RXb 02/12/12 11:42AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 02/12/12 02:14PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 02/12/12 02:19PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/12/12 02:32PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 02/12/12 02:32PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Flagrant - Flagrant - 02/12/12 02:34PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 02/12/12 02:35PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: LSLB RXb LSLB RXb 02/12/12 02:54PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: DAM' Fairchild DAM' Fairchild 02/20/12 12:24PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 02/20/12 01:15PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: DAM' Fairchild DAM' Fairchild 02/21/12 09:47AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Cooper Hennick Cooper Hennick 02/21/12 01:21PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mel Dyer Mel Dyer 04/22/13 12:04PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Dan Webber Kastner Dan Webber Kastner 02/21/12 11:19AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: GET REALIZED! BE HERE NOW! GET REALIZED! BE HERE NOW! 02/21/12 11:35AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 02/21/12 12:01PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 02/21/12 12:17PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: OGvandal MPG OGvandal MPG 02/21/12 02:23PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Adam Bandit Adam Bandit 02/21/12 12:34PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 02/21/12 12:58PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 02/21/12 01:25PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 02/21/12 01:31PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Andy Haldeman Andy Haldeman 02/21/12 09:27PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: not a Baron Asshole not a Baron Asshole 02/22/12 08:39PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Cooper Hennick Cooper Hennick 02/22/12 11:17PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 03/28/12 12:35AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: RingringBANG ! RingringBANG ! 03/28/12 08:41AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 03/28/12 10:27AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: LSLB RXb LSLB RXb 03/28/12 10:48AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 03/28/12 11:02AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 03/28/12 12:12PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 03/28/12 12:40PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 03/28/12 12:51PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/02/12 12:41AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 12/29/12 06:46PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 04/22/13 10:15AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Deadped Ryan Deadped Ryan 04/22/13 10:54AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Deadped Ryan Deadped Ryan 04/22/13 10:57AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Deadped Ryan Deadped Ryan 04/22/13 12:41PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Kevin Bishop Kevin Bishop 04/23/13 12:44AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: kron nelly kron nelly 07/23/13 02:10AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 07/23/13 11:36AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: CtpEDsHED . CtpEDsHED . 07/23/13 02:16PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 08/15/13 12:54PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: LSLB RXb LSLB RXb 08/15/13 08:19PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 08/15/13 11:08PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 08/15/13 11:52PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: LSLB RXb LSLB RXb 08/16/13 12:14AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Erik Protsman Erik Protsman 08/26/13 04:46PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Michael Thomas Michael Thomas 08/26/13 06:02PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Erik Protsman Erik Protsman 08/26/13 06:39PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 08/26/13 07:56PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: greg waldo greg waldo 08/26/13 11:43PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 08/27/13 12:34AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Eero W Eero W 09/18/13 02:46PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: will warn will warn 09/18/13 03:06PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Eero W Eero W 09/18/13 03:54PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Ryan N. Ryan N. 09/18/13 03:59PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Maciek Dub Maciek Dub 09/18/13 05:55PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: CORN PED CORN PED 07/01/14 04:44PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Dirty30 Dillon Dirty30 Dillon 07/01/14 05:00PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 07/01/14 05:26PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Tony montana Tony montana 07/01/14 07:14PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 05/28/15 04:19PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Mo Peds Mo Peds 05/29/15 11:28AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 05/29/15 12:51PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/29/15 01:41PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: will warn will warn 05/28/15 06:21PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 05/29/15 10:47AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/29/15 12:32PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/29/15 02:00PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Graham Motzing Graham Motzing 05/29/15 03:00PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: theron ross(ofmc) theron ross(ofmc) 08/18/18 01:58PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Alex Hedrick Alex Hedrick 12/22/18 05:56PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Garelli Master✨ Garelli Master✨ 12/22/18 10:00PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Alex Hedrick Alex Hedrick 12/22/18 10:09PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: Tone It Down Tone It Down 07/24/19 06:27PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 07/24/19 09:26PM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: * * * * 07/26/19 12:23AM
  Re: More info on Pietcard cdi boxes, 2013 vs 2041Re: CORN PED CORN PED 07/01/14 05:10PM
