Puch MK Performance clutch specs
- Summerai - Drew /
Weighs in at a surprisingly light 307 grams. More to come...
Re: Puch MK Performance clutch specs
- Summerai - Drew /
Purchased from New-Competition (nc-motorparts) on Ebay for under $140 shipped. Thats including the puller. The puller was only an additional $15.
Salsa Salsa /
OMG YOUR REALLY GOING TO MAKE A REVIEW?
I CALL BULLSHIT
Salsa Salsa /
What is the length of the spring?
Salsa Salsa /
looks like you should shorten it about an inch or so.
Shorten does nothing but over stretch the spring and then you lose tension.
Salsa Salsa /
Not if you change to a tomos spring.
That tomos green stock replacement spring has a rating of 9.5lbs. Wonder what the mk spring is at. What is the wire size. I know the stronger ss springs I had made are work well. It should work on these clutches. (edited)
- Summerai - Drew /
~150mm on the spring.
Yup, they will work for sure then. Thanks for sharing pics of it apart looks neato.
- Summerai - Drew /
Where can you buy those green springs?
treats has them posted and or tomos dealer. They made blue and red also but finding them is a needle a hay stack.
- Summerai - Drew /
1mm on the wire thickness.
- Summerai - Drew /
Any other info needed before I install this thing?
nerdzilla No mo Peds no mo /
How long did shipping take? And no obvious interference on a non kickstart? Could those holes be tapped for a STD puller?
- Summerai - Drew /
Took a little over a week. Again, I haven't installed it yet but ill post updates. I wouldn't drill and tap those holes, that would leave little meat near the sides of the holes. I wouldn't trust that method. Just buy the puller for $15.
- Summerai - Drew /
Installed in a standard e50 w/ lightened starter plate without any issues.
How was the spring going back on to the clutch? What trick or tips you have to offer to the next guy :) glad to hear the spring was able to go back on. (edited)
- Summerai - Drew /
Haha ed, just used my hands. I wasn't trying hard enough I guess. Post up the vid you sent me.
dude the clutch works i already told you guys.. and no you can fucking snip 1.5 inches off the spring from a tomos spring.. it makes it grab later.. i tested this clutch for at least a fucking week before i decided i wanted to build my za50.. i will be using this clutch again next week on my maxi build.. still my thoughts are it needs something like a gila kit and or an hpi cdi to give it more snap..
right now it is a light clutch but thats not enough.. I am just waiting for treats to get the mini rotor back so i can test my theory..
- Summerai - Corey Livieri /
Chill out bra....
i didn't know only one person could put up a review about something...what a crazy world we live in.
yeah im hella pissed..
Salsa Salsa /
This is dumb
- Summerai - Drew /
This really is dumb.
That is sexual chocolate
Better Fส็็็็็็็็็็็็็็็็ster /
^It is dumb. Look at that robot swingarm. Those things flex something crazy.
Salsa Salsa /
YOUR MOM FLEX SOMETHING CRAZY!
WWhhoa... More pics of that.
